Need engine help
Old May 6, 2012 | 06:55 AM
SouthernBlues's Avatar
SouthernBlues
Need engine help
l cleaned my Throttle Body yesterday and now the engine has a knocking and lacks power.
Old May 6, 2012 | 09:01 AM
Conanski's Avatar
Conanski
What did you clean the TB with? The engine knocking is most likely unrelated unless you used some unconventional substance to clean the TB. Did you do any other tunup things to the motor?
Old May 6, 2012 | 10:02 AM
SouthernBlues
Used CRC throttle body cleaner. Did not do anything else
Old May 6, 2012 | 12:26 PM
Conanski's Avatar
Conanski
Check the plug wires and plugs.. maybe a chunk of carbon is stuck in a plug and shorting it out, and look for arcing between wires or from wires to the engine, best to do this after dark with all the light off so it's real obvious.
Old May 6, 2012 | 04:43 PM
SouthernBlues
Thanks for the info, a pc of carbon was stuck in the #6 plug
tboss619
Mar 24, 2009 05:24 PM
Phishnvdub
Feb 2, 2009 07:02 PM
56flu
13
Nov 11, 2005 10:24 AM
ISHERWOOD
Sep 16, 2003 01:04 PM
The Man
May 18, 2002 10:51 AM
