Ok, long story short, we already broke this and had to epoxy it back on for temporary fix but it lasted 4 days and broke again on a bump. The little plastic fitting is broken off. Whats the part number/name for the whole assembly because we will need to replace the entire thing (that has the connector on it also) i believe. Thanks.
Yeah that was the one, found it already though, thanks man. Bracket+sensor assembly was $41 from tousley ford. Was cheaper to buy bracket too than just sensor
No problem, Its much cheaper from tousley ford than a ford dealer or fordparts.com. Should be good to go now... installing coolant filter in am. Already did full sinister EGR delete and running great, no white smoke and no coolant loss
