Lift question
Old May 5, 2012 | 05:17 PM
majkthreads's Avatar
majkthreads
Lift question
Ok I see allot guys on here that have lifted their 11-12 F250s.
I've searched but haven't come up with a real answer. If ford voids the warranty with a lift I can't believe all those guys would give up their warranty so easy.
I've seen it both way in posts that it doesn't void it and yes it does.
I've seen that it's only warrantied if ford installs it.
Just trying to find the answer. I'd like small lift in mine 2-2.5" lift.
I tow a tt so I need it to still be reasonable. Any answers would be great.
Old May 5, 2012 | 05:27 PM
doublenot7's Avatar
doublenot7
I believe you are good to go with a small lift as you are suggesting. Heck, they sell them right off the lot with lifts installed that are not FoMoCo.
Old May 5, 2012 | 11:30 PM
majkthreads
I wasn't aware of that. My truck was brought in from another dealer so it was my first and only real look at a 6.7 2012. They brought it in, I went and looked at it and bought it after driving it.
Yeah I didn't want anything obnoxious just a tiny bit higher and some new rubber all the way around. But still at the same time being able to pull our travel trailer.
Thanks for your post.
Old May 6, 2012 | 07:42 AM
Hdslider's Avatar
Hdslider
Just beware if it's not a quality lift kit, your headaches begin. A cheaper kit changes your caster,and it goes to the neg side which makes your truck feel like your on a bubble. so off to a good alignment center. If it doesn't have adjustable drag link your frt axle will sit to the left.
Old May 6, 2012 | 08:06 AM
Rex Pittman's Avatar
Rex Pittman
I am also new to lifts , i am doing alot of reading on it now and assume i will keep reading on it till i can find a "small" lift for my purdy new truck that will NOT void warranty. That being said, i could NOT think of a better place to bring a new 6.7 to get it tricked out!! Thanks for a great place to find info!!
Old May 6, 2012 | 10:20 AM
abendx's Avatar
abendx
Track bar.... the drag link doesn't have anything to do with centering the axle, it is rather a component of the steering system. The track bar is what centers the axle. An adjustable track bar or drop bracket should be the answer here.
Old May 6, 2012 | 11:05 AM
Hdslider's Avatar
Hdslider
Thank you my error.
Old May 6, 2012 | 01:16 PM
2ndStroke's Avatar
2ndStroke
A Ford dealer put a 6 inch lift on my buddies 09 f250, cost him over 5k so cost was high. Call your dealer and see what they say.
Old May 6, 2012 | 06:26 PM
mmollo's Avatar
mmollo
My dealer said a lift is no problem. Hence, I have an Icon stage III 4.5" 4 link lift on order. It's not a cheap lift by any means but you get what you pay for.
It'll be here in 2-3 weeks. Then the 35's go on. Can't wait.
Old May 6, 2012 | 09:54 PM
my996duc1's Avatar
my996duc1
A lift should only void the Ford warranty that pertains to the parts that you replaced with aftermarket parts, unless the non-factory parts have caused a problem with factory Ford parts and that problem can can be linked back to being caused by the non-factory parts.
I would not expect Ford to warranty any parts I have replaced with aftermarket parts thus voiding my Ford Warranty on certain parts.
Here is my F250 with a 2" lift and 35" tires.
Any bigger lift, I might search for some pics to make sure I didn't want to go with a larger tire.
Old May 7, 2012 | 03:57 PM
FORDTUF1's Avatar
FORDTUF1
I agree with my996duck completely.
I have a 2" leveling kit on the front as well, just put in this Friday night. I run 295/60/20 which is about a 35 x 12.50.
Old May 7, 2012 | 10:02 PM
darren32's Avatar
darren32
I have Carli pintop king 2.5 lift and still pull 12k lb 35' fifth wheel. It is a bit high in the back, trailer is on a bit of an angle sloping back but tows 10x better than stock. no sway, no bucking. The lift is 4.5" front and 2.5" back so the truck is leveled. There is noticible sag with the trailer attached. I call the look "Clampett style" but it tows great. Looks odd though...
I am old so I would not call the Carli system a "lift" from my personal experience. It is a complete suspension system. Works amazingly well, performance and handling are dramatically improved. It is amazing how hard you can pound on it off road, to the point of getting wheels off the ground.
If you are looking at this system send me a PM and I will fill you in on the pros and cons.
Thanks
motoxxxloak
Jan 26, 2018 08:37 PM
Haulinbass02
Dec 5, 2017 04:08 PM
toyowarrior
6.7L Power Stroke Diesel
May 21, 2014 11:30 AM
v8xploder
1978 - 1996 Big Bronco
Jan 13, 2010 11:20 AM
ohankeuylian
2004 - 2008 F150
May 3, 2004 03:49 PM
