rust removal
Old May 4, 2012 | 03:03 PM
jleal_21's Avatar
jleal_21
rust removal
ok guys i know some of u guys arent to fond of jeeps but ive been working on mine swapping a i6 in place of the 4 banger it had. anyhow i have removed the tub with plans on giving the chassis a little paint. the help i need from u guys is getting some of the rust that has started in the hard to reach places. two main spots that worry me are the rear shock mounts. can i just get a media blaster to do the job or is there something else? here are a few pics of my work so far.
Old May 4, 2012 | 03:55 PM
liv's Avatar
liv
You can cut those mounts off and replace them, hell just fab some up. I would go four link though =D
Old May 4, 2012 | 04:07 PM
fordpride's Avatar
fordpride
These work great for thing like that
hand held sandblaster - Product Details
Old May 4, 2012 | 10:08 PM
ReBilld's Avatar
ReBilld
Have you ever tried this? Get all the flaky loose stuff off and paint it with this. My buddy who owns a body shop says it's really good stuff!
SEM Products 38104 - Rust Shield | O'Reilly Auto Parts
Old May 5, 2012 | 09:02 AM
tshrager's Avatar
tshrager
Make sure where the rear shackles mount to the frame are in good shape. Common spot for these frames to go bad. That stuff that Bill posted seems to work well.
Old May 5, 2012 | 03:54 PM
jleal_21's Avatar
jleal_21
Thanks for the tips guys. I'll be buying those products for sure. Gotta keep my toy as healthy as possible. Lol
Old May 6, 2012 | 08:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
pressure wash the flaking stuff of. then hit what you can with a wire brush. you don't want to make it shiny clean, just get all the flaking rust scale off.
once dry, give everything a good coating or two with ospho. it is also called jasco from home depot or lowes.
active ingredient is phosphoric acid.
let it dry between coats. i spray it on with a weed sprayer.
you will know when the metal is properly treated, the rust will turn from red to black.
the phosphoric acid converts the rust from iron oxide to iron phosphate.
once completely treated and dry, prime and paint.
Old May 12, 2012 | 11:06 PM
cornbinder's Avatar
cornbinder
that is just mild surface rust, not bad at all. it would be years before it would rust threw. but some of the products the guys above mentioned will work great, and you won't have to worry bout it at all. you should see some of the ohio, michigan, pa vehicles i see and the rust issues, i've seen some scary stuff!
Old May 13, 2012 | 08:54 AM
jeep_guy48's Avatar
jeep_guy48
if you are looking to replace them or anything on your jeep these guys have everything.
Search Results - Quadratec
Old Jun 21, 2012 | 01:16 AM
jeffsonday's Avatar
jeffsonday
If you have an air compressor. Needle scalers work really well for removing rust. Its like a air hammer but it has a bunch of 1/8" pins instead of one chisel. I bought an ingersolrand one on ebay. You can get in pretty tight spot, go right around bolts they work awsome. I think theres some videos on you tube.
clintonvillian
17
Jan 22, 2018 04:00 AM
mhu
1961 - 1963 F100 Unibody
May 5, 2015 05:57 PM
TomConnell
Jul 14, 2014 08:28 PM
AndrewWV
Sep 5, 2012 10:32 PM
pintoches
Apr 13, 2010 05:48 PM
