Electrical problem.. please help.
Old May 4, 2012 | 10:54 AM
RyanW's Avatar
RyanW
My headlights, tail lights, brake lights, RPM's, and horn do NOT work.
But everything else works fine, including the interior dome light, turn signals, four way flashers, air/heat, radio, reverse lights, everything.
I've changed all the fuses, I've checked the 50 amps under the hood for the headlamps, it's fine.. just to be sure I replaced it though.. I've changed every bulb in the rear and front, and still nothing.
I'm getting desperate, I have to work tonight so I'm thinking about just directly wiring the lights to the battery, and taking the wire off the battery when i park it.. this is annoying.
Old May 4, 2012 | 01:57 PM
projectSHO89's Avatar
projectSHO89
It would likely help if you could identify your specific vehicle.
loyal
Electrical Systems/Wiring
Feb 10, 2012 05:49 PM
87Ford250
Oct 6, 2011 08:03 PM
mOROTBREATH
65
Jul 9, 2010 04:59 PM
spookypooky
Dec 6, 2008 05:51 PM
mercury man
Jan 31, 2007 06:32 PM
