what 8.8 will work
Old May 3, 2012 | 08:05 PM
f100today's Avatar
f100today
what 8.8 will work
Ok, seems like I have seen that explorer 8.8 rear ends will work on our trucks? I would assume that when they are on the explorer they are over the leaf spring? So they would work over our leaf spring? Like an axle flip. What is the story?
Old May 3, 2012 | 10:21 PM
willowbilly3's Avatar
willowbilly3
Yeah, sit on top of the springs in the Exploder. Plus the Exploder has a weird angle on the leaf spring so you will need a major wedge or reweld the perches to get the driveline angle right. Not sure on the width, maybe a little narrow.
Old May 3, 2012 | 10:25 PM
HIO Silver's Avatar
HIO Silver
Why even consider an 8.8? I mean, ya can swap out the chunk for different gearing in about half an hour.
Try that with an integral carrier.
Old May 4, 2012 | 01:15 AM
bmuhlbach's Avatar
bmuhlbach
I believe the face of rotor to face of rotor there 61.inches
Old May 4, 2012 | 09:26 AM
aric1979's Avatar
aric1979
I put a 1993 F150 8.8 in my 1979. Bolted right up no problems
Old May 4, 2012 | 10:06 AM
HIO Silver's Avatar
HIO Silver
Full size Broncos and F-series up to 96. If ya need brackets, contact A&A Manufacturing.
Old May 4, 2012 | 11:33 PM
willowbilly3
Because they are easy to find, cheap and a good rear end, you can get them with disc brakes. Plus if you need a limited slip they can be had for a lot cheaper than a 9". If you foresee a need to be swapping gear ratios, then yeah, stick with a 9"
I had a 3.73 8.8 with limited slip and discs that cost a buck fifty at the junk yard.
wdglide
21
Dec 4, 2017 04:22 PM
scoutbuff
Bronco II
May 25, 2015 03:00 PM
ETOWN55
35
Jan 24, 2015 07:14 AM
chrono4
Mar 6, 2005 11:31 PM
chrono4
Jan 31, 2005 03:21 PM
