Speed specific vibration between 47-50 mph
Be nice if all the posters that had the similar issue would have followed up too. Hope they all got rid of the vibration.
Surprising how often it's a driveshaft though. Especially the double-cardan type on some of the trucks.
I wonder if some of them had the hubs locked and the front was causing a vibration?
Paul
Is yours the single-joint at each end type of shaft? Or does it utilize the double-cardan style joint at the transfer case?
If the singles, it's easy to over-torque the u-bolts (for the u-joints that is) and crush the cup into submission. This results in a very short bearing life in the joint and, very likely, a vibration.
If you'd just changed the lift height of the suspension at the same time, I'd suspect a rear pinion angle issue. Was any other work done to the truck before this started? Maybe extra weight added to, or removed from, the rear? Springs changed? Anything at all along those lines?
There's another thing that can happen to even a new shaft. They can be assembled out of phase. For those not familiar with that, it's when the two halves are assembled with the splines out of kilter. So the two u-joints are fighting each other rather than enhancing each other.
Easy to tell if it's way out, as the caps won't align with each other when you imagine a straight line up the shaft.
If it's only one or two splines off however, you either need a good eye, or take the shaft off and lay it on the ground or other flat surface. The caps should both lay flat on the ground at the same time. No offset or rocking allowed.
Just a thought, since you said you had a new shaft.
Good luck.
Paul
Good luck.
Paul
I did install an aluminum flatbed to replace the heavier 8' bed. Next time I pull a load with the goose-neck will see if the vibration lessens, which it just might. Will report observations in a couple of weeks.
Truck is otherwise stock and not lifted--it's still a work truck and belonged to my father. 400 cleveland motor replaced original 351c, 400 has about 30k on it; total vehicle miles about 130k. I've been driving it with the vibration for the last 9k miles since 2012.
But you can still check it pretty quick if you have the time to take. With a decent angle finder you can check the relative angles of the front and rear u-joints in the shaft. Or put differently, the angle of the output shaft of the transfer case and the angle of the rear axle pinion. They should match, I believe to within about 3° of each other. I think?
Optimally they'd match almost exactly, but there is some leeway allowed. And the rear pinion "climbs" during acceleration and fall during deceleration anyway, so it's constantly changing.
But if in it's neutral position the two joints have too much angle differential then you will get the vibration. Especially under just certain circumstances, such as when you accelerate (as yours is doing) or decelerate.
Vibration upon acceleration would usually indicate a rear pinion pointed too high to start. Then it just gets higher as you push on the gas.
Although, being a 250 instead of a 150, those big heavy duty spring packs in the rear are not known for being too flexy and allowing much pinion climb/axle wrap.
Still, doesn't hurt to know. Interested to hear what happens when you load it up.
If you decide to measure, a digital angle-finder is the ticket. You can get pretty close with the old style dial type, but they tend to stick and might miss a couple of degrees here or there.
Good luck.
Paul
