New clutch needed?
Old May 1, 2012 | 01:13 PM
bwheaty's Avatar
bwheaty
New clutch needed?
Got a problem, clutch peddle suddenly became very stiff, clutch not working (still grinding gears with peddle depressed), new process 435 4-speed connected to a 390. 76-F-250. I haven't had the pleasure of cracking into the tranny/clutch yet in the 30 years I've had the truck. What do I need to check?
Thanks!
Old May 1, 2012 | 01:23 PM
bertha66's Avatar
bertha66
Did you check the rods on the linkage to make sure nothing broke?
Old May 1, 2012 | 02:45 PM
bwheaty's Avatar
bwheaty
I crawled around down there and looked but didn't see anything out of line. That I could tell, anyway.
Old May 1, 2012 | 03:01 PM
hickory1991's Avatar
hickory1991
Chances are its time for a new clutch, pressure plate, and throw-out bearing. Bearing may be froze to trans shaft. Probably have to pull trans to investigate. Let us know what you find. Good luck.
Old May 1, 2012 | 03:35 PM
bertha66's Avatar
bertha66
If you crawl under the truck, have someone else push on the clutch pedal and see if all moves.
Old May 1, 2012 | 06:38 PM
bamaf150's Avatar
bamaf150
With the wheels chocked, brake set and key in your pocket
BradBryan58
Apr 20, 2018 08:49 PM
Jespo80f150
Jul 11, 2012 04:04 PM
jgib90
Aug 25, 2007 10:06 PM
BeltDriven
Mar 16, 2006 03:37 PM
94bonestocker
Nov 24, 2005 05:35 PM
