replaced tps, still running wrong
Old May 1, 2012 | 12:46 PM
joekacker's Avatar
joekacker
I was having issues with my truck , bouncing idle, bad throttle response, hard down shifts, engine braking, and really bad pulling while trying to maintain constant speed. sounded exactly like a bad tps. So I changed it out, cleaned the throttle body ports out . my truck is still doing the same crap, and the engine light turns on for a few seconds then turns off, every few days or so. I have odb1 system, every auto parts place has odb2 hooKup and cant read my codes.Is there a way to diy at home? and Would a bad fuel injector cause engine light to come on?
91 f150 5.0
Old May 1, 2012 | 03:29 PM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to get the trouble codes.
Or you could buy an Equus 3145 code reader for around $25.00 to make life easier.
Old May 1, 2012 | 04:18 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Check out this thread it may be your problem.
A9x ECM's (and same years ECM's) Failures Due to Age
Trevor Whitten
Mar 21, 2019 05:29 PM
sgauvry
Jul 27, 2013 04:35 PM
richdavis69
Dec 29, 2011 04:12 PM
jgentle
Dec 20, 2005 09:52 PM
cdbreez
Jun 19, 2002 08:43 AM
