2000 SD started,ran good...parked, now won't crank
A good friend of mine has a 2000 F-250 7.3L PSD. The truck has been running good, starting good, but last night after making a 20-min stop, it wouldn't do anything when turning the key. Dash lights, door chime, headlights all work, but no cranking, nothing, not even clicking except for once. Even though the batteries were replaced last fall, I suspect battery/contact issues, but I don't know much about diesels. Any other ideas/suggestions? Thank you.
I had the same issue that would strike at random. I checked fuses, relays, etc. and for me it was loose screws. Seriously. When they get loose enough the shifter doesn't go fully in to park even though the tranny is in park. Even if it's not these screws, it won't hurt to make sure. Here's a pic for you:
Yep, when I was having my trouble that was the same symptoms I had: in & out park a couple times and she'd start. After tightening those nuts.... no more issues. Let us know what fixes it for you.
rrhode23
1997 - 2003 F150
10-02-2010 08:35 PM
