Lifting or leave stock?
Old Apr 30, 2012 | 12:59 AM
vikingpride15's Avatar
vikingpride15
I have a 1995 F250 4x4 with a 7.3L and I'm debating whether to lift it or leave it at stock height. My truck is immaculate, and I've had no problems with it which leads me to my question. Is lifting it going to hurt it? I've had it up on blocks to see where a 6 inch lift would put it, and I like how it looks. But I don't want to do something that's going to mess up my truck
Old Apr 30, 2012 | 01:16 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Welcome to FTE! It is often said that lifting a D50 will cause ball joints and stuff to wear out faster once its lifted, especially over 6 inches. Theres also guys who say they don't have any problems with it.
Ford4Life7.3
But other than that, no it will not harm your truck. That could all be avoided by doing a dana60 swap for your front dana50 if it turns out to be a problem
Old Apr 30, 2012 | 01:21 AM
vikingpride15
Thanks, I appreciate your input. If I do decided to lift it, I'm doing all suspension. Any specific lift you'd reccomend?
Old Apr 30, 2012 | 02:18 AM
jg96powerstroker's Avatar
jg96powerstroker
i have a skyjacker 6in on myn, a lot of guys have done a sky kit , i would do a d60 with any lift, this is my 3 truck that is lifted and d60 is the way to go man trust me ,
Old Apr 30, 2012 | 08:56 AM
Redneckmorton's Avatar
Redneckmorton
I have a 96 F350 CCLB 4x4 with the d60 up front. I went with the ORU's Shackle Reversal Kit and 1" over stock leaf springs. This gave me roughly 3 1/2" of lift all together and I can run 37s with out a problem. Now they do rub just a touch on the driver back side with a full lock to the left, but not bad enough.
I did this cause it gave me the ground clearance that I was looking for and kept me close to stock "ride height" so it wouldn't mess with to many things. I think it even improved the ride a little.
I had thought about going with a 4" lift on top of the ORU's Shackle Reversal Kit but 6 1/2" of LIFT would get you on up there.
Old Apr 30, 2012 | 09:36 AM
vikingpride15
Thanks guys
Old Apr 30, 2012 | 10:06 AM
redman84's Avatar
redman84
A dana 60 with one of the lifting RSKs is totally the way to go and probably not much different from the cost of a decent lift kit.
Old Apr 30, 2012 | 11:37 AM
pjwoolw's Avatar
pjwoolw
Replacement OEM type springs and poly bushings. You'll be good to go for years to come.
Old Apr 30, 2012 | 12:56 PM
Ford4Life7.3
An RSK or a all suspension kit from Skyjacker is the way i would go if it were my truck. Don't go the cheap way and use a kit from somewhere like rough/tough country. Too many people have had problems and say the springs flatten out rather quickly
Old Apr 30, 2012 | 01:05 PM
Awitte58's Avatar
Awitte58
I have the d60 with a 4" skyjacker suspension. Springs front blocks back.
It rides like a hay wagon... but is structurely sound.
Wish I woulda done the RSK swap thing though..
Old Apr 30, 2012 | 01:23 PM
redman84's Avatar
redman84
^^Always a good choice too.^^
Old Apr 30, 2012 | 09:41 PM
JamesHajek's Avatar
JamesHajek
I'd lift it...
Old Apr 30, 2012 | 09:44 PM
BuckHammer's Avatar
BuckHammer
I wouldn't lift the stock TTB axle. Take the resources that you would expend to lift the TTB and use them for a monobeam Dana 60 swap. That way you'll have a much more solid foundation to start playing around with if you wish.
Old Apr 30, 2012 | 10:44 PM
vikingpride15
Ok, thanks for all of the advice. I talked to a local guy here in town who does a lot of the lifting and performance stuff in my area, and he agreed with all of this. I've been thinking about a lift for about a year now, and I've decided to get one. I'm going up 6". Now, any recommendations on wheels? I have the xlt package, so I'm thinking 18" chrome wheels. I've been looking at the Fuel Hostages, but I've seen them on too many trucks around town.
