Offroad & 4x4
TTB Action
Old May 1, 2012 | 08:35 PM
  #31
alpha/omega's Avatar
alpha/omega
Originally Posted by fatdan460
kris, i'm sad to say this, but ttb's are the new hot setup for bling buggies ala k.o.h. rigs :shaking: don't ask me why, but companies are even coming out with high dollar bling axles for them and a few are trying to develop stronger bolt in centers from what i've read. it's like the damn twilight zone reading about it
Ive seen that. The "cheap" sets start at just under 2k...without u-joints which are a little over $200 each.
Ive never debated the fact that they do handle bumps/hills/jumps well. What Ive said is they do not handle mud rocks and heavy trail use much beyond stock size tires and mild offroad conditions. Theres too much going on in the axle at any one time to hold up to much abuse.
Old May 1, 2012 | 08:42 PM
  #32
njneer1's Avatar
njneer1
I am actually impressed with it.......so much so that I am keeping it.......moding it to 8 lug and doing long arms and a small lift....swapping the rear to D60.
https://www.ford-trucks.com/forums/1...he-bronco.html
If I break it....... I'll drive down there to the flatlands and buy you a beer Alpha !
Old May 1, 2012 | 08:49 PM
  #33
alpha/omega
Good for you. Im not easy enough on my trucks for a TTB to last.
Old May 1, 2012 | 08:58 PM
  #34
njneer1's Avatar
njneer1
Those speed bumps in SC must be higher than I remember. The TTB is holding up here in the mountains.
Old May 1, 2012 | 09:15 PM
  #35
rudedogii's Avatar
rudedogii
Twin I-beam TTB
while i don't have as much ttb hate as most, i still think they are junk. bad design and besides being more complicated, they tear up frames from the stupid amount of leverage they have when they are really being worked hard.
Baja racers have been using the twin I-beam suspension for years. Checkout "AutoFab" or "Camburg" suspension on the web sometime. I'll try to post a link.
Old May 1, 2012 | 09:30 PM
  #36
hav24wheel's Avatar
hav24wheel
HUGE difference between TTB, and TIB.
I for one know a STOCK hight TIB pickup with 4 inch TTB springs on it will jump like there is no tommorrow. I wish I had some pictures, but my 74 F100 2 wheeler had more air time than a twin seat Cessna.
  #37
rudedogii's Avatar
rudedogii
TTB Links
Here's a link to Solo Motor Sports.
Bronco PreRunner
Old May 1, 2012 | 09:41 PM
  #38
njneer1's Avatar
njneer1
Bronco PreRunner
Awesome !!
Old May 1, 2012 | 09:47 PM
  #39
njneer1's Avatar
njneer1
[quote=hav24wheel;11780630]HUGE difference between TTB, and TIB.
Same concept....but with a drive axle.....not really seeing the huge difference you speak of.
Old May 1, 2012 | 09:51 PM
  #40
hav24wheel's Avatar
hav24wheel
3 ujoints for one..... The joint at the diff and the slip joint there is a major weak spot. Usually the first to give out. The TTBs are press formed steel welded together, vs cast steel. Ive had TTB axle that was all cracked up and needed some extensive welding to keep it in service.
Old May 1, 2012 | 10:17 PM
  #41
rudedogii's Avatar
rudedogii
Auto Fab
Autofab TTB Bronco
Extra Wide Model 44
Old May 2, 2012 | 08:37 AM
  #42
tjc transport's Avatar
tjc transport
i ain't rite
i had a TTB D-50 break in half on a truck that was never off road, street driven only.
and saw 5 or 6 others that broke in the same place, right at the driver side spring.
the dana TTB axle is a poor design. the axle tubes are thin box steel compared to the thick cast tube of a solid axle.
Old May 2, 2012 | 10:54 AM
  #43
alpha/omega
Pretty much sums up my feelings...
Originally Posted by STGFordCrazy04
Definition of Twin Traction Beam (TTB) Tee Tee Bee ~
A Twin Traction Beam (TTB) front axle is found in 83-96 Rangers/Explorers 80-96 F150s and 80-98 F250s. Its like a independent and solid axle had a late night drunken stupor sex-o-thon and had a basturd child. The only beneficial worthwile or nice thing I can say about them is they ride good on road while stock and absorb hard bumps offroad in like prerunner trucks. In all other applications they suck. It works very similar to the twin I beam suspensions of 2wd trucks. The axle is hinged on a crossmember that allows each tire to move independently of the other. They are expensive to lift even slightly over stock. The higher the lift the more stress it compounds on to the frame and TTB crossmember and it leads to stress cracks that drastically weakens the frame and is extremely dangerous. Common TTB sizes are D35 (rangers/explorers) D44 (F150s) and D50 (F250s). TTBs are much weaker than their solid axle counterparts. Anyone wanting tires larger than 35" and plan to wheel their truck with any amount of confidence MUST switch over to a solid front axle swap (SAS).
TTBs bring the suck!
I wonder what ever happened to this guy?
Old May 2, 2012 | 11:19 AM
  #44
tjc transport
i ain't rite
no idear.
Last Activity: 03-10-2012 07:55 PM
he has no points, and is not in the band.
Old May 2, 2012 | 11:27 AM
  #45
alpha/omega
Last I heard he caught some strange Middle Eastern strain of syphilis from Karls wife and possibly went crazy from lack of penicillin.
