Stubborn brake drums
Old Apr 29, 2012 | 12:27 PM
investedocean's Avatar
investedocean
My 85 f250 4x4 has a Dana 61 rear end in it. I am unable to get the brake drums off. I have adjusted the tensioners on each side and sprayed lubricant around the studs and center. Then i used a BFH hitting it in different spots especially between the studs trying to get it loose. Unfortunately I have only a propane torch at my disposal as far as heat is concerned too. Anyone have any tips for removal for me to try? Thanks
Old Apr 29, 2012 | 12:58 PM
ctubutis's Avatar
ctubutis
You need to remove the axles and the 2.5" nuts inside to get the drums off.
A Boy and his Jeep » Dana 60/70 Rear Drums
Old Apr 29, 2012 | 01:05 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Once you've done one of those you will understand why some of us prefer the Ford/Sterling axles. My drums slide off.
KRinAZ
Apr 2, 2018 12:22 PM
ranscobia
17
May 13, 2015 08:48 PM
64dave
Sep 20, 2007 07:23 AM
vjl99
1997 - 2003 F150
Jun 1, 2006 04:14 PM
macushla1
Jul 22, 2002 08:09 PM
