Shift lever
Old Apr 26, 2012 | 01:44 PM
GOVTMOD's Avatar
GOVTMOD
Shift lever
OK, what are my alternatives to the the miles long, staff of the ancients, shift lever that swings from sea to shining sea as you work your way through the gears? I know it doesn't have to take up the entire center 3rd of the cab so no one can sit in the middle. Is there an aftermarket option? Has anyone reshaped theirs, chopped it or anything like that?
I figured at the very least I could cut it down 4-6", rethread it for the **** and give it a bend more towards the driving position. Not like it's breaker bar heat treated or anything. What have you guys done about this issue?
Old Apr 26, 2012 | 01:58 PM
montana_highboy's Avatar
montana_highboy
I've never found the long throws on a NP435 to be an issue, i actually find its ergonomics pretty comfortable, but if you're after a short throw NP435 this may be of some help....
short shift np435 - ClassicBroncos.com Forums
Old Apr 27, 2012 | 07:35 AM
GOVTMOD's Avatar
GOVTMOD
I'm not wanting to do a swap out right now but that is good info. It looks like some of the guys in that thread did something like I was thinking.
I actually don't mind the swing or pattern but it is pretty wide and it means no one can sit in the middle which I more than likely will need. I do believe I'll chop off the top and get to bending. I might even bend the transfer case handle a bit to get it more out of the way.
codeman2443
Aug 20, 2014 09:00 PM
bhiggins
Sep 27, 2006 10:44 PM
Rockwell
Jan 2, 2003 07:07 PM
fordlowboy
Aug 15, 2002 06:48 PM
