offenhauser 360* intake?
Old May 1, 2003 | 10:12 PM
coacholy's Avatar
coacholy
Is the offenhauser intake is bad as everbody thinks it is? Is it worth to swap to a edelbrock performer? I am running a mild performance cam and 10:1 compression and headers and a carter afb on top?(Its a 390 four speed in a f100)
Old May 2, 2003 | 06:24 PM
gtex's Avatar
gtex
I have not heard anything bad about the Offy intakes. In my opinion, the intake is one of the last places to spend money, unless you still have a 2V intake.
Put the money somewhere else. If you do decide get an Ed intake , get the Performer RPM.
Old May 2, 2003 | 11:23 PM
FE427TP's Avatar
FE427TP
I think that on my 360 the offy 360* equaflow had a bit more low end, but when I would check plugs the outside 4 were significantly different dark or lighter dont remember which than the inside 4, when I swapped to a Performer RPM they all became the same color
Old May 6, 2003 | 07:02 PM
coacholy's Avatar
coacholy
I've read some articles saying that the offenhauser doesn't flow very well but neither do stock heads. So is it worth it to switch to edelbrock performer instead of my offy 360* ?
Old May 6, 2003 | 07:11 PM
gtex's Avatar
gtex
Like I said before, I think the differences the intake can make are marginal.
With your setup, you might expect 10-20 HP from the best intake choice. I think even less. Now , if you get some head work done, you could upgrade the intake. But, pulling the Offy intake for the gains I think you will see, I wouldn't bother. Not unless you plan on doing some other mods and are pulling the intake anyway.
my 2 cents
enriched&beyound
29
Sep 6, 2022 05:55 AM
udsuth78
Jul 28, 2012 07:04 PM
Joeseph
WTB - Parts & other
Mar 31, 2011 05:49 AM
charles jones
Feb 15, 2006 04:44 PM
brown 4x4
Mar 2, 2001 12:44 PM
