This is for a 1967 F-250.....was running fine, then one morning, no power whatsoever....
Checked battery and it read 0.32 volts, disconnected it from the truck and it immediately jumped to about 3.5 volts.
After recharging battery, reconnected it to truck, got a spark as i connected the terminal......noticed, with keys OFF, my aftermarket Tach was showing 2000 RPM and gradually dropping as battery drained.
So, swapped coil - same thing
Disconnected points/tach from the coil - **strange part** - when I reconnected the positive terminal this time, the engine began trying to turn over(ignition off / no key in the switch)....
No burn wires visible.....with everything off, I'm reading at least a 0.5 volt load on the battery.....
Seems I heard before a bad Voltage Regulator would try to make the alternator into a motor.....is this what's happening? How to test?
Uni, The spark on battery connect dez there is a dead short somewhere.
Are you sayin that you have made no changes under the hood in the last 3 weeks or so???
John
Yup....no changes...that's why I originally was thinking that one of the electrical components had failed.
Well, the only other out of the ordinary thing is my speedometer cable seems to have broken.....but I don't think that could have any electrical interactions....cable casing still intact and all....
The reading 2000 RPM on the tach with engine OFF and the strange engine rotating on it's own feel like they could be symptoms....but I can't find anything good on the Voltage Reg or the alternator other than "swap them out and see if it's fixed"
Lets keep this very simple. Disconnect the negetive terminal from the battery. Then recharge the battery to full charge with the ignition switch off. Then connect a test light between the battery ground post and the vehicle ground cable.If it illuminates you have a electrical draw.You may start a prilimanary search for the source by removing fuses from the fuse box to see if the light goes out. If it does,you have a circuit to trace.
FWIW
Fenceclimber
....You may start a prilimanary search for the source by removing fuses from the fuse box to see if the light goes out. If it does,you have a circuit to trace.
FWIW
Fenceclimber
Did the prelims already....still drawing and ruled out starter and alternator.....So, starting with fuses in the morning....
Starter relay is definitely bad for it to start with connecting the battery. I had that happen with a 77 F-150 and a 74 AMC Gremlin with a Ford starter. Are very cheap to replace. Luckily the F-150 was in reverse in the garage, as it backed out by itself.
So.....oddly enough, nothing seems to be wrong this morning.....battery charged up overnight, no draws of voltage on any systems, started up and was charging at 14.12-14.16 volts......????? (I hate electrical issues!!!! lol)
Ordered new solenoid and Ignition switch to be sure.....
The only thing I completely disconnected was the car stereo, to rule out any power draw for it's memory.....perhaps it was fried somehow?
Wondering "IF" the ignition switch was screwed up and actually left power to the points(burnt them) thus causing current to coil and tach. All this mayhem caused the battery drain. Then the bad switch then got worse and caused the solenoid to activate making it try to start.
That switch is the only things that activates/controls all the things that went haywire. That is why I would start there.
I must agree wit rusty wheel an freightrain with the solenoid, do you have a good ground between the battery,body ,frame and engine ? I have seen some strange things result from bad grounds. Kenny Nunez
I was having electric issues thought it was all fix, couple of the times the starter did not quite. Friend of suggest checking hooking up correct grounds, have not had a problem since. Did not lreally have a good chassis ground hooked up.
Grounds would be cheap and easy to check. You have two...one is the neg batt cable that grounds on the passenger front engine block...just follow the cable from the batt to the block. The other should run from a bolt on your throttle linkage mount, driver's side rear of intake, to a small bolt/screw on the firewall...pretty short cable, maybe 10 -12 inches max. I recently replaced my intake to firewall ground and truck is running much better...old cable insulation was toasty and broken in places, with wire showing through. Also check your batt ground cable for corrosion inside the insulation. Took me about 35 minutes to pull both cables, clean connections with a wire brush, and reinstall both cables.
