the official OBS diesel off topic thread
Received 3,112 Likes
on
the idiot was doing a tug of war against a big engine jacked up truck and decided to even the field by making his attach point 3 foot above the bed floor after attaching everything to the frame.
in the bed was 5 1400 lb concrete blocks for traction weight.
the combination of the truck pulling in 4X4 and the high pull point folded it like a napkin
Unrelated to 6 door cabs or dodge trucks but...
my dipstick adapter started leaking! NO!!!!
I bought a new one when I swapped the first 7.3 in last year, and re-used the same oil pan. I tightened the adapter up which has slowed the leak a lot, but I'm sure it'll start leaking more now that this happened.
What am I going to do with my life now!? It had 0 leaks as well!
Here's another option, I haven't used this tho
Ford 7.3L Dipstick Tube Oil Pan Adapter Powerstroke oil adapter dipstick adapter | eBay
Hmm those are all good options. I'll see how much my current dip stick nut is leaking then decide on if I want to spend the money to stop the leak now or not.
I thought I'd be leaving in 3 weeks to go to basic, but that now moved up some which I'll find out probably Thursday when that will be. Maybe an additional 1 to 3 months before I leave, which will give me time to see how I should go about fixing this leak!
My best friend did that last summer with a Pontiac G6. Fell asleep on his way home from work. He walked away, but it did a number to the car. It was a miracle that he walked away. And that wasn't the first time he was in a bad accident and walked away either.
That's like exactly what happened to the truck I grabbed my good motor from.
It was a white f-250 where he hit a pole and was debating on fixing it, but decided to part it out. It something like that happened to my truck, I'd end up fixing it. Sure it might take a while, but I couldn't get rid of my truck now!
