ordering
Old Apr 23, 2012 | 09:54 PM
turbo diesel fan's Avatar
turbo diesel fan
ordering
Ok im going to order my head gaskets. Do i need rear main seal or is it just a top end repair?
Old Apr 23, 2012 | 10:47 PM
RacinNdrummin's Avatar
RacinNdrummin
Are you just replacing head gaskets?? Are you turbo'd? If you are or plan on it, spend the money on studs, even if you have to borrow the money from somebody.
That being the case, an upper end kit will get you by.
Old Apr 23, 2012 | 11:14 PM
turbo diesel fan
I need head gaskets and yes im turboed. So i can get studs and a top end kit and not have to worry abkut a rear main seal and etc?
Old Apr 23, 2012 | 11:16 PM
turbo diesel fan
Yes im replacing head gaskets. I can get studs. If i get studs i can do a top end repair and not have to worry about a rear main seal and all that?
Old Apr 23, 2012 | 11:21 PM
RacinNdrummin
Yes, exactly.
Old Apr 24, 2012 | 09:23 AM
rolape2's Avatar
rolape2
If you have the engine out, and depending on mileage. Check if there is a groove worn where rear main seal rides. If so you might want to put a speedi-sleeve on the crank, cheap insurance. Prevents having to pull something to do it later.
Old Apr 24, 2012 | 09:25 AM
turbo diesel fan
I havent pulled the motor its still in the truck. So im just going to do studs and head and top end gaskets
Old Apr 24, 2012 | 10:42 PM
Aune163rd's Avatar
Aune163rd
I wouldnt do a single thing with heads with the engine in the truck, its a PITA....a MAJOR...PITA
Old Apr 24, 2012 | 10:50 PM
RacinNdrummin
I agree, its a major PITA to do in the truck... But its not impossible, and really not much more of a PITA than pulling the engine and doing them while its out. The only benefit to that is that you can clean everything up a lot better...
Old Apr 27, 2012 | 09:18 PM
rolape2's Avatar
rolape2
If you do it in the truck, do a search on doing studs in the truck. Others have but there is clearance issues on passenger rear. I did mine with engine out so can't really give full details. If you can't find I can help some.
Old Apr 28, 2012 | 12:21 AM
Bonanza35's Avatar
Bonanza35
Just wondered why you are doing head gaskets. Did one blow or what. Bad valve. Thanks
Chet
big_country
Aug 7, 2012 01:23 PM
bdad57
Mar 10, 2006 07:29 PM
sftchinook
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 8, 2005 01:12 AM
red75bronco
Mar 3, 2004 12:16 PM
Boss_358
May 20, 2001 11:48 PM
