05 expy headache
Old Apr 21, 2012 | 11:43 PM
Jtanner76's Avatar
Jtanner76
05 expy headache
My 05 expedition is missfiring at higher rpms. i thought fuel, so it has new filter, new pump. and it still missfires real bad at high rpms. Sometime it does it at lower rpms. I get different codes, so far miss in cylinder 5. Later one for 6. After i replaced the Fuel pump, now i get one for Evap Emissions too high at the switch. Sorry i dont have the actuall codes in front of me right now. I do have a nice scanner, so i can see certain live data from my computer. For example my Fuel Pressure to Vac is 39 psi at idle. Not sure what normal is.
Old Apr 22, 2012 | 02:12 AM
5.4T's Avatar
5.4T
sounds like coil packs, who told you to replace the fuel pump?
Old Apr 22, 2012 | 12:26 PM
Moto Mel's Avatar
Moto Mel
It sounds like the crankshaft or camshaft position sensor is dying. I would replace the crankshaft position sensor first. It is located on the passenger side in the front cover under the A/C compressor. Available at nearly all parts stores and in stock for about $20.00.It's pretty easy to change too.
Old Apr 22, 2012 | 04:58 PM
alloro's Avatar
alloro
How many miles on it and are the spark plugs original?
andyy
Escape & Escape Hybrid
Jan 1, 2017 01:12 PM
83sd
31
May 12, 2015 07:07 PM
fordtrucksj
Oct 5, 2011 07:57 PM
jwrboss302
17
Feb 16, 2010 09:23 PM
