Hello all,
Ive got some squeaking going on when i take off from a start but goes away. So i took off the rear brake check calipers added some new brake quite. Put back together still getting the noise climb under the truck sounds like the rear u joint so im going to replace all of them and the carrier bearing .Just wondering wich ones to get. THANKS IN ADVANCE.
One more thing it only will do it going forward just took out of the garage pull forward and backwards.
Hello all,
What ever you buy make sure there are grease fittings, imo. Moog & Timken are good name brands .
if you look closely at the u-joints, you should be able to see rust/brown dust around the caps of the one that is bad.
but when i get u-joint squeak, i just replace them all.
Thats good info, I have my drivers side axel out right now. The u-joint feels good and looks fine too, that gives me something else to ckeck!
yes im going to replace all of them and the carrier bearing . what weird is it only has 58,000 miles i guess i need to drive it more. Im looking at the splicer u joints.
