Limited slip or electronic locking???
Old Apr 22, 2012 | 12:11 PM
PrinceValium's Avatar
PrinceValium
So how do you know if you are getting open differentials on the front of the 4x4? Watching that first video...I would have thought that in 4 wheel drive being on that roller wouldn't have mattered. Seeing that first video the 4 wheel drive isn't doing anything so what's the point of putting an open differential on it??
Old Apr 22, 2012 | 12:14 PM
flixden's Avatar
flixden
The front usually has an open diff in stock configuration on 4x4 trucks. Since the transfer case is not a diff (or you could look at it as a completely locked diff), you at least get one front wheel to help pulling in the worst case.
Old Apr 22, 2012 | 12:17 PM
PrinceValium
I guess it just goes against everything I think a 4 wheel drive was...I look at it as all 4 wheels pulling regardless. Sad to see that is not the case.
Old Apr 22, 2012 | 12:24 PM
flixden's Avatar
flixden
In a truck with 4WD and:
- open diffs: 2 wheels will drive worst case
- locking rear: 3 wheels will drive worst case
In a truck with 2WD and open diff, you'll have only one wheel driving in the worst case.
A 2WD truck with a locker is similar to a 4WD with open diffs in that two wheels will be trying to push forward in the worst case, just with the 2WD locker, it's two wheels on one axle, with the 4WD open diff it's two wheels on different axles. Depending on the terrain or specific circumstances, one could be better than the other, even the 2WD with locker *could* be better off than the 4WD with open diffs.
The ideal case would be a LS diff in the rear with a locking option, and then a locker in the front. On top of that, I'd have 2LO on my wishlist. Now everything would be covered.
Old Apr 22, 2012 | 01:08 PM
PrinceValium
I do understand what you are saying...its just when most people buy a 4x4 they believe all 4 wheels will be spinning when engaged....which to me is what 4 wheel drive is!
Old Apr 22, 2012 | 01:30 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I will say that vids prove GM's point. But, I've owned 4x4 trucks since 1986 and my dad before me since 1976.
Together we've both owned open and LS diffs and never really had any issues that GM is saying that you will experience without and Eaton ale.
My '86 F-150 4x4 had 3.08 open diffs and my '88 4x4 had 3.73's, LS rear. My 2011 has 3.31 open diffs, no elocker.
Each of my three trucks felt great off road. My '11 feels a bit more sure footed mainly due to it's power and weight.
Good driving and great tires can alleviate most situations. Though I think GM is on the right track with the Eaton, I look at it as a marketing gimmick more than anything. Much like the Allison Transmission if you will.
Clearly Ford has seen a benefit to an open diff that can be locked on demand. Likewise Ford sees a benefit to an LSD for the HD trucks.
Old Apr 22, 2012 | 02:38 PM
PrinceValium
Hmm...
Did you get my PM?
Old Apr 22, 2012 | 03:13 PM
640 CI Aluminum FORD's Avatar
Those are some great videos! Especially the first one simulating a launch ramp. IS this the type of EL on the F150? I thought when you engage the EL by pulling out the **** it is locked immediately not when it senses slipping? BTW that rear tire on the last video looked like it was going to break off! Just by watching these videos I think the EL is the way to go. Thanks! Reps sent.
No its not the same...I mean essentially they do the same job, however GM's G80 rear locker is activated only by wheel slip as the videos indicate. I beleive Ford uses a Detroit selectable in their trucks, which means that in only functions when the **** in the dashboard is pulled out.
I don't beleive GM trucks have a selectable option as theirs is automatic.
Old Apr 22, 2012 | 03:27 PM
PrinceValium
Maybe that would be better I don't know. I think about getting the truck and pulling the boat out of the water and slipping on the wet ramp. I have not had that happen yet with my two wheel drive Sequoia...but going to different launches you never know what you will face.
Old Apr 22, 2012 | 03:37 PM
tseekins's Avatar
tseekins
Hmm...
Did you get my PM?
Nope. You may want to resend.
Old Apr 22, 2012 | 07:19 PM
meborder's Avatar
meborder
This applies if your getting an XLT or Lariat truck. The 3.73 LSD is still offered on the STX trucks for $400.
this is only true for the 3.7L v6.
the 3.7 trucks get the venerable 8.8" ford rear, for which LS is availble
the 5.0's get the bigger rear, and they don't offer the LS outside of the max tow, which you cannot get on the STX
Old Apr 22, 2012 | 09:43 PM
flixden's Avatar
flixden
Originally Posted by meborder
.... the 5.0's get the bigger rear, and they don't offer the LS outside of the max tow, which you cannot get on the STX
You mean HD payload, right?
Old Apr 22, 2012 | 10:07 PM
  #28
meborder's Avatar
meborder
yep .... my bad .... sorry
HD payload comes with LS 3.73's
max tow comes with open or Elock 3.73's
neither of which are available on the STX.
i dont remember who said it here, but i agree that ford is making some unpopular decisions with regard to the differential options they are providing their customers.
Old Apr 23, 2012 | 07:02 AM
  #29
Rob.D's Avatar
Rob.D
So which rearend would be a better fit for my wife, LS or Elock? I will be ordering a 2012/13 Max Tow, Crew Cab, Lariat, 3.73 for her as a daily driver? She is 80% highway, 80 mile round trip daily. Michigan winters
Old Apr 23, 2012 | 08:24 AM
  #30
Ford8502's Avatar
Ford8502
Unless something changes for the 2013's, you don't have a choice. They only offer the ELock in that configuration. If you add the HD Payload package then you have to get the LS.
