What is this???
Old Apr 19, 2012 | 03:01 PM
WK15's Avatar
WK15
What is this???
Ok, I was looking around under the hood and noticed these black pads surrounding both batteries.
Are these pads heated or non-heated to prevent the batteries from freezing? I tried long up this number but no luck.
Thanks
Old Apr 19, 2012 | 03:19 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Thanks
I can't find then on a parts site.
From my experience....... They might be "Blankets" that are used to shield the battries from the high heat of the engine. Heat is the biggest killer of battries.
Old Apr 19, 2012 | 03:35 PM
SavageNFS's Avatar
SavageNFS
battery blanket and insulator. No power to it...keeps the engine heat away from the battery.
Old Apr 19, 2012 | 05:10 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
battery heat shields. the 6.4 only had only one (driver side) as it was the warmer location. 6.7 has em on both sides. i swapped out my batteries from my 6.4 to my 6.7 at the dealership when i did the trade in. the salesperson asked me the same thing.
Old Apr 19, 2012 | 05:18 PM
WK15's Avatar
WK15
Thanks guys
Old Apr 20, 2012 | 08:41 AM
FishingNut's Avatar
FishingNut
Just curious why you did that? You just bought new batteries and they were of better quality than the OEM ones I am guessing...
Old Apr 20, 2012 | 09:32 AM
Tuxedo Scorpion
Good guess. Had just bought a pair of 1000cca absorbed glass mat's to replace the flooded cell 750sor that are oem. Which suck imho for many reasons, mainly they arent sealed and were venting that lead to a corroded terminal that nearly ate the entire connector.
Old Apr 20, 2012 | 09:45 AM
kper05's Avatar
kper05
On your new truck?
My OEM batteries have never failed me or caused any harm in 30,000+ miles.
Old Apr 20, 2012 | 09:48 AM
Tuxedo Scorpion
On my 6.4 with 56k and 4 years old. 3 of 4the terminal were fine, but the one that was corroded was so bad that the terminal separated from the battery
TooManyToys.
Dec 13, 2017 07:28 PM
gonzos XLT
Escape & Escape Hybrid
Feb 13, 2013 10:17 AM
2020
Jul 17, 2012 04:06 AM
ssharber
6.4L Power Stroke Diesel
15
Mar 24, 2010 05:45 AM
DonJames
Jan 21, 2007 10:39 AM
