I guess I have been doing it all wrong all of these years. The can of avionics cleaner and a bit of di-electronic grease is way to cheap. I need to buy that $100.00 kit.
But I guess if I were in the business, and did it everyday, it might be worth it.
I know from working on aircraft that the most frustrating gripe can lead right to a corroded cannon plug.
Even funnier is when you go to put up that new tool,
You discover the best place to store it is right along side the other 3 or 4 copies of it you had to go buy because you COULDN'T find it the last 3 times you needed it
