What are yalls oil and trans temp on average when good and warm? Considering no load, just every day cruising. I see 200 EOT and 190 on trans. Is that high for the trans? I am running 37" tires and 6" lift. Thanks for any input.
That's not high. Sitting at idle oil temp will settle from 200 down to 194 and trans will settle into the mid 180 range. Running on interstate will get the temps you describe, maybe up to 206/196.
I also get an oil temperature of 200 or 200 and a little more. Transmission temperature is less, about 195 and a bit more. My first surprise was to notice the oil temperature is consistently higher than the transmission temperature.
