460 no start
Old Apr 16, 2012 | 11:28 PM
beckman's Avatar
beckman
460 no start
hi guys i have a 1986 ford f350 4x4 with a 460 engine and it wont start
it turns over good, it has spark, compression was 120 all the way around
and there is fuel at the carburetor when you move the linkage any help greatly appreciated thank you
Old Apr 17, 2012 | 06:15 AM
Bump187's Avatar
Bump187
Wow, could be 100 things.
How long has it been sitting not running? Original carb?
Does it have electric or mechanical fuel pumps? If electric, are they running?
Spark plug wires in the correct order?
Does it even try to start or just crank over?
Old Apr 17, 2012 | 06:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Compression, spark and fuel are all you need for an engine to run.
If the plugs are clean and dry there shouldn't be a problem getting a spark. Perhaps it's coming at the wrong time?
Old Apr 17, 2012 | 08:27 AM
Bump187's Avatar
Bump187
well....... Sort of. Its not exactly THAT simple. He has all three of the above and it doesn't run.
Too much, not enough, or incorrect timing of any one of the three "components" above and you have no running engine.
Old Apr 17, 2012 | 12:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
....That's why I said if the plugs were dry the ignition could be out of time.
Obviously he has enough of an accelerator pump shot that the engine should pop, even if the jets are so clogged and it won't run.
If the plugs are clean try it on ether.
If that doesn't work there's definitely an ignition issue.
Old Apr 17, 2012 | 02:08 PM
82f100460's Avatar
82f100460
certainly sounds like ignition alright. heck you can dump fuel down the throat and It'll at least try to start.
What have you done lately to the engine? Have you messed with the coil, distributor, module? Anything? Replaced the dist. cap maybe?
Just having spark don't tell us if it's at the right time.
How did you determine you have spark?
Old Apr 17, 2012 | 11:01 PM
beckman's Avatar
beckman
she runs
thanks guys for the reply not sure why it wasnt running but it is now
Old Apr 17, 2012 | 11:33 PM
82f100460's Avatar
82f100460
sounds like maybe you have an intermitent loose connection somewhere in the ignition system?
Emil460
Sep 24, 2015 06:27 PM
John McCabe
20
Nov 11, 2014 01:19 PM
North_of_60_F250
Jan 18, 2009 02:48 PM
free1973
Dec 6, 2008 08:14 PM
scrapyardking
Jan 3, 2008 12:25 AM
