I've been driving it for some time (over 6k miles) without a front sway bar. I was always concerned by the amount the vehicle would roll around in a strong wind...now I know.
EDIT: After a quick search, it's obvious the links broke.
But, here's the thing. I'm under the front of the truck every 5k for oil changes and I have never noticed this before.
So, it looks to be a DIY job and I'll need to buy some new hardware as one of the links has a vertical crack in it and is showing it's age. And, on top of this, I'm curious if, at 130k on the clock, if I should be looking to rebuild anything else on the front end. I'm also debating on whether or not I should send the truck in to a mechanic to have them go through the front end...decisions, decisions.
I 'd check all suspension parts period. Both tie rod ends, ball joints (my lower driver snapped out of no where) & control arm bushings. The stabilizer bars are an easy job. Just finished mine.
To do the passenger side I had to jack up the driver side a-arm to make room to even slide the sleeve between the sway bar and the lower control arm on the passenger side. Used jack stands, on both sides, it is not only safe, but it makes the job easier. I tried jacking up the passenger side control arm to put in the sleeve for the stabilizer bars it didn't work for me. Good luck to you and it only takes less than an hour to do them. Well easy for me to say, I had everything already out of the way when I decided to to them !!!
See Ford changed the way the sway bar stabilizer links look mine look completely different.
Since I been known to screw up, scuff, and or dent the heck out of stuff. I took duct tape and wrapped a bag and some clothes around my axle teeth. I should have just taken it off and moved it completely out of my way instead, but was too lazy and already mad at all the rust. So left that shaft right on in there,lol.
Ford didn't change the way they were connected-Moog figured out a far better way to do it. You can still actually buy the old, crappy Ford OEM links. I had the same thing happen to me a couple years back. Replaced them myself in an hour. The worst part is getting the old ones out.
that was the best part in my book, removing them crappy oem swaybar links
