Sponsored by: Real Truck
Hydroboost leak?
Old Apr 16, 2012 | 04:35 PM
armysoopertrooper's Avatar
armysoopertrooper
Hydroboost leak?
Took my F250 6.0 into the dealership to get serviced, oil, tranny flush, etc. and the tech noticed a leak from the hydroboost module. Now I think I can figure out the basic function of this module, in that it has a compressor and appears to have chambers to provide hydrolic pressure to various systems, front and back brakes, and power steering.
The tech obviously didn't look close to where the leak was coming from, as it isn't coming from any part of the module housing but from one of the high pressure lines that comes out of the left side of the module body, as you look at it from the front of the truck. The leak drips down from that fitting onto the module body and onto the stearing column.
So the parts guy that schedules and manages the tech's time said I needed a new $480 Hydroboost and have it installed. I told him to order it, which they did and charged me, but I didn't want to have them install it until I had a chance to look at it myself and ask questions.
I know hydrolic fittings can get damaged, but is it safe for me to attempt to tightent this fitting? I'm sure there are some 'O' rings in there, and that may be where my problem lies, but the location makes it problematic because the reservior for the DOT3 and the engine coolant reservior are in the way. And I mean, completely in the way.
Bottom line, I would rather not spend the money if I don't have to. It has cost me enough already.
Thanks Community.
DBGrif91
May 30, 2013 05:57 AM
armysoopertrooper
Apr 30, 2012 06:30 PM
anpbabaki
Aug 13, 2009 04:28 PM
96eddie5.8
1978 - 1996 Big Bronco
May 7, 2005 11:50 PM
