Backfiring Issue
Old May 2, 2012 | 07:55 AM
saxtonj's Avatar
saxtonj
I have had 3 coils go bad in the past year. I just put this coil on a couple weeks ago. It ran great until the sputtering and backfiring.
Is there an other issue the truck could have that would be eating up my coils?
Old May 2, 2012 | 09:36 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd really be surprised that 3 coils would go bad in a year. Condensers are famously poor quality nowadays. If you disconnect the condenser you can run a short time for troubleshooting, it just is bad for the point contacts.
If you are 6v (+) ground, make sure the coil is designed for that and is hooked up that way. Hooking up a coil designed for (-) ground on a (+) ground car will be bad for it.
Some 6v cars used a ballast but others didn't. The truck wiring diagrams don't seem to show one?
Old May 2, 2012 | 01:09 PM
saxtonj's Avatar
saxtonj
According to the "bench tests" all three read way out of specs ohm readings when truck would not start. I replaced with new coil(used same condensor) each time and truck would start right away and run fine until I would go out and it wouldn't start. This is the first time it started running bad while driving it in the 11 yrs I've been driving it. This time I replaced all ignition parts and it ran great... for a while.
Check me here... but I have coil connected with hot to ignition and ground to distributor...?
Old May 2, 2012 | 01:23 PM
harleymsn's Avatar
harleymsn
I had the SAME situation last fall. Could not figure it out until I pulled the coil. I was sure that the FlameThrower coil was still good, till I saw that the top had erupted. Replaced it with an epoxy filled solid coil, no problems since.
BTW, coil failure, especially new coils, is not unusual.
MWB323
29
Sep 25, 2017 06:28 PM
Mutt1984
13
Jul 30, 2015 06:15 AM
dustytheredneck
Jun 17, 2012 11:16 PM
VintageBlueOval
Oct 14, 2009 06:49 AM
rebel_ford4x4
Oct 24, 2005 10:57 AM
