Sponsored by: Real Truck
PCM removal
Old Apr 15, 2012 | 06:53 PM
bigbadgixxer's Avatar
bigbadgixxer
PCM removal
03 need to get code for mike. Computer is under drivers dash 2 bolts. Do I unhook battery first then just pull it out?
Thanks Tim
Old Apr 15, 2012 | 06:54 PM
bigbadgixxer
Sorry 6.8 4x4 F350
Old Apr 16, 2012 | 07:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You need to unbolt the connector from the PCM - The bolt/connector is on the engine side of the firewall.
Mike can actually send you the tuner first, and you can use that to read the code, if you don't want to mess around with removing the PCM.
Old Apr 16, 2012 | 11:36 AM
Bigpipes 35's Avatar
Bigpipes 35
Why do you think you need to remove the pcm ?? I didnt have to on my 03 , the codes are on the outside of it...
Old Apr 16, 2012 | 11:39 AM
bigbadgixxer
I guess mike said I just need to remove plastic cover/shroud
Old Apr 16, 2012 | 11:56 AM
Bigpipes 35
yep thats all you have to do..
90pioneer
16
Apr 30, 2013 11:45 AM
shadows4
Modular V10 (6.8l)
Dec 19, 2011 06:30 PM
DIXIEDOG1
Nov 13, 2010 08:06 PM
roller_steve
16
Dec 2, 2006 08:22 AM
Dwinn
Computer Chips & Tuners
Oct 7, 2005 10:01 PM
