Where do I look?
Old Apr 15, 2012 | 09:01 AM
DaveBB's Avatar
DaveBB
Where do I look?
Hi. I'm helping a friend transplant a 2001 Mountaineer 5.0L into an early Bronco. We got it running the other day. Now I'm hooking up the cruise control that came from the 01 Mountaineer and need a speed sensor signal. We got a vss that goes in the speedo cable then found out that on the 01 Mountaineer the signal from the speed sensor is processed by the 4wabs module.
Sure wish I could find a company that makes a vss signal converter aftermarket that makes one so I won't have to use the 4wabs module to get a signal for the cruise control. Anybody know what to do here?
I found one forum that talks about using the GEM from a 2001 Ranger 2.5L to do this but not only are they hard to find but I'll need a pinout or wiring diagram for it so I can hook it up right.
Ideas?
Old Apr 15, 2012 | 09:32 AM
deck60's Avatar
deck60
vss
rostra makes one that hooks up to the drive-shaft it is made for their cruise control but I really don't know why it wouldn't work for you app
part #
250-4165
there are 2 on ebay right now just put part # in for search about 50.00 including shipping
Old Apr 15, 2012 | 10:02 AM
DaveBB's Avatar
DaveBB
I think I won't be able to judge weather that one will work because I don't know what signal is required by the 01 Mountaineer cruise control module. Square wave? amplitude? Sine wave? If I knew this then I'd have to pry this info out of a manufacturer of a vss. Then how to use a 2 wire vss when the cruise has a 1 wire input. Does the other one ground? Who knows?
Old Apr 15, 2012 | 10:08 AM
deck60's Avatar
deck60
my guess is that it would have a 12v + input and then the other wire would go to the vss I think it is just a simple magnetic reed switch you could also try banner
Sensors » Products & Applications » Banner Engineering Corp.
most speed sensors are just a simple signal switch that detects a pulse
Old Apr 15, 2012 | 10:14 AM
DaveBB's Avatar
DaveBB
Thank you. Nice site. I should email them to see if they have a solution.
Old Apr 15, 2012 | 10:19 AM
deck60's Avatar
deck60
TURCK - Capacitive Proximity Sensors, Inductive Proximity Sensors, Connectors, Cables, Cordsets,
bot of these deal with industrial applications whether it is counting or speed proximity beams both are good and both have weather tight connections
I am an industrial maintenance tech so I deal with these on a daily basis
Old Apr 15, 2012 | 10:40 AM
DaveBB's Avatar
DaveBB
That's another nice site. Thanks. Now if I only knew the requirements of the 01 Mountaineer cruise control module, what wave and amplitude and also what terminals the 2 wires go to, I could probably do this.
Old Apr 15, 2012 | 11:00 AM
deck60's Avatar
deck60
you have 2 terminals I would check and see if you have voltage coming out of one
could 12v + or 5 v +
I really don't think they used a sine wave on this app I think it is a simple pulse
ford like to use pulse signals I have found that out on my tach on my conversion
so if it is a pulse then the rostra will work you just use magnets as the pulse
it probably doesn't really care what speed you are at just as long as it keeps the pulses within a the spec range so the more magnets like 6 would be a finer adjustment than say 2 magnets
I think you are trying to make it harder than it is look at a pulse instead of a sine
you could try a cam sensor off a ford and ground one side this is what seems to work on the tach sensors
that would be a cheap junk yard fix
Old Apr 15, 2012 | 11:21 PM
DaveBB's Avatar
DaveBB
This is a quote from another forum. GM. I think this kind of says something about what my questions are about. I find info like this in lots of forums but I still don't know what my cruise module needs for a signal.
On the left (referring to picture) is a "4-output vehicle speed buffer" used on vehicles with electric speedometers. It gets the vehicle speed signal from a 4 pulse sine-wave generator mounted at the transmission, and converts the sine-wave into a square wave signal for the ECM, speedometer, cruise control, and on some models, the radio (to control volume with the vehicle speed). 1990 and newer TPI engines have the buffer incorporated into the ECM, and the ECM outputs the square wave to the speedometer, cruise control and radio.
Old Apr 16, 2012 | 12:30 AM
deck60's Avatar
deck60
they use a tone ring with a sensor and then into the abs box that is the same way my wife's escape works
could you use a tone ring and sensor from one of the wheels off the mountaineer
just wondering here
Old Apr 16, 2012 | 12:43 AM
DaveBB's Avatar
DaveBB
just wondering here
The Mountaineer is gone now. I would still need to convert the sensor info into something the cruise module can use. In the Mountaineer the 4wabs does that.
Old Apr 16, 2012 | 08:17 AM
deck60's Avatar
deck60
what are you using for your spedo to make it work could you pull the vss of that
I was thinking ford likes to use its sensors to ground so the sensor provides the pulse and the wave is provided inside of the cruise unit
case in point the rpm on a superduty we use the cam sensor and ground one side so then it reads resistance as a pulse
my glow plug light if I ground it then it comes on so it had to be ran through a relay
just a thought
Old Apr 16, 2012 | 08:32 AM
DaveBB's Avatar
DaveBB
We got a vss that goes into the speedometer cable and it produces a sine wave pulse not a square wave. I think a square wave pulse is needed by the cruise unit but I'm only guessing.
I posted a picture of the wiring diagram in post #11 but I don't know if it worked. I can right click it and view it.
I would try using a GEM from a 2001 Ranger 2.5L to convert the signal as I found info about on another forum but I can't contact the guy for a wiring pinout of the GEM.
Old Apr 16, 2012 | 08:57 AM
deck60's Avatar
deck60
Convert sine to square
how to convert sine to square
from my reading square is digital and sine is analog am I correct on this
you could always just buy a rostra and be done
Aftermarket Cruise Control, Daytime Running Lights and Hands-free Bluetooth by Rostra
randye
Aug 11, 2013 01:52 PM
fetchitfido
Oct 6, 2009 05:48 PM
bduff007
Aug 8, 2009 12:05 PM
byrd95
1978 - 1996 Big Bronco
Apr 20, 2003 11:46 PM
dclark
Apr 22, 2002 10:31 AM
