I am having trouble finding king post bushings for my 64 f 100 the steering has been getting tight and the passenger side wont take grease so i assume thats the problem i tried fmc but only found 65 with coil spring not sure if they will work I would appreciate any advice
i tried fmc but only found 65 with coil spring not sure if they will work NOT the same!
Zerk (grease) fitting on passenger side prolly clogged up (as original, 45 degree). Common-used for over 50 years on gazillions of different vehicles...available from any autoparts store.
1961/64 F100 2WD's have a straight axle with leaf springs. 1965 and later F100 2WD's have Twin-I-Beam front suspension w/coil springs.
1957/64 F100/250 2WD: FoMoCo only supplied kingpin bushings separately for the standard size kingpins. The .010" O.S. kingpin kit (B7TZ-3111-A) had to be purchased to get the bushings.
