Climate Controlled Seats (issue?)
Old Apr 17, 2012 | 09:00 PM
  #31
Raymow's Avatar
Raymow
Originally Posted by Tuxedo Scorpion
truck went back to dealer today for further investigation/troublshooting. they gave me a free rental car, which was good of them. also pointed out a minor manufacturing defect in a trim piece that was driving me nuts. they were more than glad to help out with my concerns. very different from other dealer experiences ive had. although first time with a new vehichle and dealing with the service dept from the dealer that sold me the truck. got my fingers crossed that i will have the kidney freeze that others "complain" about
let us know how it turns out, and with the remote start, my seats did not come on the last 2 days and temps are high, my dealer did not have time to look at mine they want to reschedule.
Old Apr 17, 2012 | 10:21 PM
  #32
jdadamsjr's Avatar
jdadamsjr
Curious how each of you are setting your ac when u shut down...
on all my previous fords, whatever it was set at is where it came back to on remote start...
i.e. if ac was set to 72 and it was 90 in the Ex, it would start at HIGH fan and full blast to cool off quickly...
I've had the 12 on auto and recirculate and the seats on high, but it never really restarts on high and the seats are certainly not on...
trying a new tack as of today = set it on max ac to see how it does...
Old Apr 18, 2012 | 12:07 AM
  #33
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
How about choosing the "Auto" setting ???
Old Apr 18, 2012 | 08:11 AM
  #34
jdadamsjr's Avatar
jdadamsjr
Yeppers, Auto is where I started like on all my other fords...
but not doing what I expected, so trying other settings now
Old Apr 18, 2012 | 01:02 PM
  #35
doczenith1's Avatar
doczenith1
Originally Posted by Biggziff
The seat heater/coolers do not use the HVAC system in the truck at all. They are thermoelectric units that cool or heat depending on the polarity of the voltage being fed. The interior temp of the truck may have a slight effect on their ability to produce heat or cold, but not much.
Well said!
Old Apr 18, 2012 | 04:15 PM
  #36
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
just heard back from ford on my seats. they have been in close contact with engineering on the matter. they have made temperature comparisons to another 2012 truck in their inventory and cross referenced the technical specifications regarding temperature tolerances and differences. apparently the system is designed to have a 10 degree difference between seat back and seat bottom. bottom being cooler. and since my seats fall within tolerance, they have determined them to be operating properly. fine with me. as long as i know theyre right, i have no complaints. maybe i wont experience kidney freeze, maybe i will if the conditions are ideal for what it takes. either way, the dealer was very pleasant to deal with on the concern and adressed my other concern as well. (a defect in the chrome ring trim piece around the cupholders on the console - yes minor, but hey I paid good money for the rig, i want it perfect)
Old Apr 18, 2012 | 04:22 PM
  #37
2000silverbullet's Avatar
2000silverbullet
The tolerance of the temps is good to know, that would explain why they're not the same temps, or at least don't feel the same.
Now if only they could come up with a solution for the crooked sunglass holder in the overhead compartment. lol...
Old Apr 18, 2012 | 04:26 PM
  #38
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Use a 3 lb Ballpeen Hammer..... It'll fix it
Old Apr 18, 2012 | 04:34 PM
  #39
Tuxedo Scorpion
What's crooked??
Old Apr 18, 2012 | 04:38 PM
  #40
2000silverbullet
What's crooked??
Sorry for the quality..
Old Apr 18, 2012 | 04:40 PM
  #41
Tuxedo Scorpion
D'oh!! Did u ever adress it with them?
Old Apr 18, 2012 | 04:43 PM
  #42
2000silverbullet
Yeah but they "forgot" to address it the last time I had it in. It seems alot of them are like that though...
Old Apr 18, 2012 | 04:46 PM
  #43
jdadamsjr's Avatar
jdadamsjr
Seems easy enough to 'tweak' it yourself a bit....
open it and gently pivot it 'the other way'
it is light plastic and will move
Old Apr 18, 2012 | 05:12 PM
  #44
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
SNAP
Have Fun
Old Apr 18, 2012 | 05:21 PM
  #45
2000silverbullet
Yeah I'm not good at tweaking things, I tend to hit that threshold where they break, then I'm out $50, or $500, whatever the case.. lol.
