HIO Silver's Lo-Buck Bumpside Build
#781
That is why my last sentence suggested you FIX the problem. And a 235/75/15 is a pretty dang narrow tire which would only compliment your concern about the stagger; sorry it would make your truck more of a tail dragger. But hey, its your truck, you can put a 13 inch wheel with a 21 inch tall tire on it if thats what you need to do to get it to "sit right".
It's wearing 30x9.5x15 on all fours right now and doesn't look bad... but it looks like something is wrong with the suspension more than it visually conveys that itsa modified Bump.
.. tomorrow is another day.
#783
That's not a bad idea. Hmm... I might have to look into that. This is after all going to be a quasi-shop truck. I'm out of room for any more vehicles and planning to move on and build blue oval engines.
#784
I have a set of Monroe air shocks on the back of mine and you can sure put it where you want it.
#785
#786
#789
#791
Air shocks don't ride very well and are really just a band-aid for saggy suspension springs or, springs that don't have enough rating to support the load being placed on the vehicle.
Air shocks also place a lot more load on the shock mounts than the mounts were designed to handle. --this goes back to the suspension springs. The springs are designed to set the vehicle height and to hold the vehicle and its loaded weight up. Shocks should just be for the purpose of controlling jounce and rebound of the axle. Not load support or vehicle lift/lowering.
#792
The exhaust was literally "wrapped" last weekend: https://www.ford-trucks.com/forums/1...l#post14965911
#795
No.. not overly concerned.The engine doesn't rock very much and the tubing is pretty much centered with 0.5 to 0.75 clearance all around. If it does hit then I'll cut and modify the X-member until it doesn't.
