Tie rod end.
Old Apr 12, 2012 | 08:17 PM
F350-6's Avatar
F350-6
Tie rod end.
Any suggestions on what brand tie rod end is a good one? I've got a nasty clunk when turning the wheel that I've traced back to a tie rod end that I installed not too long ago. I installed the Moog "problem solver" and the stupid thing is popping so loud it's driving me crazy.
I'm thinking I'll just do the driver side for now since that's the source of the noise and just measure 12 times before and after so I can hopefully skip the alignment.
What brands have you had good or bad luck with? I'm thinking of just going with the generic, private label parts store brand this time since Moog didn't last a year. The stock ones went over 350k, but was getting a little sloppy.
I also burned out a headlight bulb. It's been a rough day.
Old Apr 12, 2012 | 08:44 PM
7.3 Rocket's Avatar
7.3 Rocket
Just put XRF tie rods on my truck this afternoon.
They come with a million mile warranty to the original purchaser so long as you've got the receipt.
Paid $300 for everything. between the pitman arm and knuckles.
Old Apr 12, 2012 | 08:49 PM
caverjoe's Avatar
caverjoe
I thought moog was lifetime. Ball joints are anyway. Might ask where you bought em at.
Old Apr 12, 2012 | 08:58 PM
F350-6's Avatar
F350-6
The part is pretty cheap (except for the XRF) and I was less than impressed with the quality to begin with. The bottom plate the zerk fitting screws into was so thin the fittings don't want to stay threaded in. I have to hand thread a new fitting in each time I want to grease them.
I was looking for another (inexpensive) brand to try since my stock ones seemed to last for so long. I'm not sure I want to spend the money on the XRF parts, but I do have their ball joints.
Old Apr 12, 2012 | 09:07 PM
danskool's Avatar
danskool
Go Bills !
I just use the Napa brand, forget the manufacture of them. Not sure if they are lifetime, i will have to check with him if he even kept the receipt.
No alignment. No issues. Just measured everything
Old Apr 12, 2012 | 11:09 PM
duck fan's Avatar
duck fan
Because racetruck
I am putting XRF on this weekend too.
Old Apr 13, 2012 | 01:12 AM
4inchlovin's Avatar
4inchlovin
lol i dont remember what brand i put on but im happy with it... im usefull i know.
Old Apr 13, 2012 | 06:43 AM
brian42's Avatar
brian42
Veteran: Navy
I replaced everything about 20K miles ago from the pitman arm to the knuckles. Since the OEM lasted me over 190K I went with OEM again. The OEM hiem joints are greasable anyway which is the only reason I would have switched. With the OEM I know it's going to be a perfect fit.
Old Apr 13, 2012 | 09:31 AM
Fat Diesel's Avatar
Fat Diesel
Chris since your stock one lasted so long why not put another OEM one in? Bring it out to the Nor Cal GTG tomorrow and we'll get it swapped out!
Old Apr 13, 2012 | 10:56 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I am still running stock parts in my personal truck as well (288k miles..)
We have replaced them in several of our work trucks though. I'm told we used the NAPA brand. According to my service guy...he says they carry a standard and Heavy Duty brand. The HD brand is a closer match to OEM parts so that is what he uses. So far we haven't had to replace any NAPA parts...
I asked him to dig up a receipt to see if it had any part numbers. If he find one, I'll post back with the info...
Old Apr 13, 2012 | 06:19 PM
BadDogKuzz's Avatar
BadDogKuzz
Pete what is XRF ?? Could you please post a link ?? Thanks !!
Old Apr 13, 2012 | 06:32 PM
duck fan's Avatar
duck fan
Because racetruck
Since I have the same name and went with the same products... XRF has a million mile warranty and have great reviews. I picked mine up from these guys: The Tire Club
Old Apr 13, 2012 | 06:38 PM
sand_fiend's Avatar
sand_fiend
I installed there kit and ball joints about a year ago. So far they seem great.
Old Apr 13, 2012 | 06:39 PM
7.3 Rocket's Avatar
7.3 Rocket
^ What the Californian said.
Got my truck aligned today by measuring end to end on everything before reassembly they only had to tweak it 1/16" to get it just right. Will likely purchase XRF products again when it comes time for ball joints on my truck.
Old Apr 13, 2012 | 07:01 PM
BadDogKuzz's Avatar
BadDogKuzz
Thanks Pete & Pete !!
