Tig Welder Question
Old Apr 20, 2012 | 04:24 PM
  #46
1951flatheaddave's Avatar
1951flatheaddave
I dont have anyone to show me the basics, I was going to just get some scrap and start practicing. I have watched a few videos and read some articles so In my brain I have an idea of what to do but practice makes perfect I guess.
I am looking into a bench grider to dedicated just to grinding electrodes. I dont have one yet but I did hear it is mandatory.
I have a nice welding table I made for my mig, its similar to what you described above. I think I can make it work ok for the little I am going to use this welder.
I have an autodarkening hood from when I bought my mig, will I use the same shade setting as the mig or is the tig brighter? I use my mig on shade 9.
Good call on the welding outfit and gloves, weld sunburn is very painful, got it once and learned my lesson!!!
Old Apr 20, 2012 | 07:42 PM
  #47
lexcoe's Avatar
lexcoe
Ron Covell has quite a good video on Tig welding basics to get you started. Well worth the price and cheap on somewhere like Amazon.
Being comfortable is a must, sitting is best and then practice, practice, practice, prac......
John
Old Apr 20, 2012 | 10:54 PM
  #48
AXracer's Avatar
AXracer
Tig isn't as bright as mig so unless you are welding heavy material, 9-10 should work. I'm going racing at 4AM tomorrow for the weekend, when I get back I can answer any questions you ran into.
Old Apr 21, 2012 | 12:50 AM
  #49
HT32BSX115's Avatar
HT32BSX115
6 year old IBM desktop computer with win 95
OMG! The only thing worse than WINXP was WIN95!
Originally Posted by AXracer
Do you have someone to show you the basics? Do you have a dedicated grinder with a wheel that has never been used and never will be used for anything but grinding electrodes? First thing you want to build is a welding bench. I'd suggest ~ 24 x 36 top of 3/16-1/4" un warped steel plate on 48" high steel legs. Pipe legs with pipe flanges bolted to the top will work or use square tube to make a top frame and legs. Set the legs in ~ 6" from the edges so you can clamp pieces to the top. Use a comfortable adjustable height chair to sit on and have plenty of light directed on where you are welding.
You definitely want a self darkening helmet that is adjustable from 9-12 plate final darkness. Look in the hot rod magazines like Street Rodder or Hot Rod for a page of Harbor Freight coupons. Their helmet works well and you can get it with coupon for ~ 36.00! For tig you want light weight snug fitting all leather work type gloves, not the heavyweight welding ones used for MIG or stick welding. You need to be able to feel and feed the filler rod, the gloves are only needed to protect from UV rays, not heat or splatter. Don't use gloves with any fabric parts. Wear a long sleeve 100% cotton shirt (blue work shirt or old dress shirt type), and watch for exposed skin at neckline with helmet down unless you like strange sunburn patterns. No matter what you see the clowns on TV doing, NEVER tack or weld without a helmet!!!! Sunburned eyeballs and/or face is very painful!
Dittos Dittos and more Dittos!
Stephen67
17
Aug 4, 2012 11:57 AM
Soldierboy
Garage & Workshop
Jul 26, 2006 11:29 PM
yota
Garage & Workshop
Sep 3, 2004 01:52 PM
astrotaz
Garage & Workshop
24
Mar 21, 2004 06:26 PM
cjcathey2002
Garage & Workshop
19
Aug 22, 2003 07:30 PM
