Rough Runnning At Start-Up ?
Old Apr 22, 2012 | 08:43 PM
dlibson's Avatar
dlibson
Originally Posted by Jojofour
My 2005 did the same thing and from their it has been nothing but down hill. If I am you I would get rid of it asap before you have more problems $$$$$
LOL
Don't waste time posting like this...
Old Apr 23, 2012 | 08:24 AM
jimmyv13's Avatar
jimmyv13
YES, DO THIS!!!
All 2005's are the exact same, they all suck.
Old Apr 23, 2012 | 10:09 AM
Getsome68's Avatar
Getsome68
I took it to a shop to have them look at the hard start issue and they couldn't get it started so they never had a chance to get to the alt or the 4wd issue. All they could tell me was that the FICM was dead. My guess is a vacuum actuator.
From what I've read on here and on ficmrepair,com the 6.0l is very sensitive to voltage and with either a alternator or battery's not at 100% condition you run the chance of killing your FICM. Read ficmrepain.com FAQ section and they have a lot of great information.
After I send out my FICM I'll be getting my alternator replaced then starting on fixing the 4wd part.
Old Apr 23, 2012 | 10:36 AM
PSD2005's Avatar
PSD2005
Theses are the kind of guys that don't do Maintenance! All they what to do is drive them!! They are really great trucks, the best riding truck ever!! Don't listen to guys like this!
Old Apr 23, 2012 | 06:32 PM
Getsome68's Avatar
Getsome68
What maintenance can I do to prevent my head bolts from stretching?
Old Apr 23, 2012 | 08:48 PM
BLADE35's Avatar
BLADE35
Let the truck get to a ECT of 150* or higher before you get on it Hard
Dont run a Tuner without ARP Studs (some do run custom tune for a NONStudded trucks havent heard any problems here) so dont throw any off the shelf tunners at it SCT ONLY IMO
Keep your turbo Clean or address the veins if they stick overBoost will lift heads/stretch the bolts anything above 28psi Boost is pushing it Get some Gauges to keep an eye on it
Keep an Eye on your oil cooler/egr cooler if the egr cooler Bursts and coolant goes into the cylinders the cylinder Pressures SKYROCKET thus stretch bolts/lift heads so AgAIN GET SOME GAUGES if you dont already
Gauges are a Great thing to Have regaurdless IMO
Old Apr 23, 2012 | 09:00 PM
BLADE35's Avatar
BLADE35
So let me ask you this
Do you run out and trade in your Auto everytime it Breaks down.
ALL AUTO ANY MANUFACTURE will break down at one point or another
Just seems Like that would be the MOST EXPENSIVE Route to Go IMO
But I will Give you a little slack in return here being that ANY AUTO/MAKE has GOOD/BAD Ones. And By ALL Means if you Got a BAD ONE I DONT Blame you at ALL for Getting rid of it Hell I would dump it to.
But Its Not RIGHT that you get on here and Basicaly SAY that there ALL a POS cuz that IS NOT the Case
You are ONLY a Statistic of 1
Old Apr 24, 2012 | 08:44 AM
nitrogen's Avatar
nitrogen
gee i haven't had any real issues with my 05 so there is at least ONE 05 that isn't a POS. pretty amazing really, they built how many 6.0's in 05 and based on your personal experience of what 5 maybe 10 the other 350,000 units are all junk. GTFO all you do is prove just how stupid you really are. 110,000 miles one egr cooler and oil cooler around 60k IIRC FICM just before warranty ended( I knew what symptoms to tell the dealer I was seeing (: ) it didn't act real bad, but when they tested it it didn't pass. without the knowledge from the site I would have run it til the FICM failed on my dime.
d450heavy
Jun 14, 2013 11:15 PM
tuskfire8
Texas Chapter
Nov 29, 2012 02:51 AM
kpbankey
Jul 13, 2011 09:43 PM
Amarillo 6.0L
Oct 21, 2010 09:35 AM
my72ford
Bronco II
Feb 20, 2006 07:04 PM
