Steering box to frame problem
Old Apr 12, 2012 | 08:27 AM
fiftyfordfloored's Avatar
fiftyfordfloored
Hey, question... Is that same rivited piece on a F350 frame (maybe the same piece as a F150)? I can't remember how mine is... but I'm in the process of cutting a frame up, and if it's the same, your welcome to the piece I have (the rest is going to scrap anyway). Let me know and I'll take a look when I get home.
Old Apr 12, 2012 | 12:15 PM
4x484150's Avatar
4x484150
I actually just bought the frame repair kit in question from green sales. ($60)
It will fit the Bronco and F150-350. Not sure of the years, but I believe it was intended for all the trucks 80-96.
Takes a lot of work to put it in. Needs welding to install it.
Old Apr 12, 2012 | 03:46 PM
hardtrucker8629's Avatar
hardtrucker8629
CTUBUTIS, thank you very much for your help. I ordered the kit that i needed, many thanks again.
Old Apr 12, 2012 | 05:04 PM
82f100460's Avatar
82f100460
It's probably considered part of the frame itself and therefore not listed independantly in the MPC
Old Apr 12, 2012 | 05:42 PM
ctubutis's Avatar
ctubutis
Glad to help, hardtrucker.
The parts catalog doesn't show any views from the angle of Ron's picture nor can I find any discrete views or even a mention of that thing anywhere.
This leads me to agree to agree with Kevin, it's probably considered part of the frame itself and not a separate part.
It'd be cool if you guys who are installing it could post pictures of what you have and what you do to install it/fix the problem.
Old Apr 12, 2012 | 06:18 PM
cactusbronco's Avatar
cactusbronco
I had the exact same thing happen to my '85 4wd just recently. My friend is an excellent welder,ground notches along the cracks, drilled 3/16 holes at each
end of the cracks and welded everything up. It is still holding. You have to get the areas as clean as possible and get very good penetration. I think I am going to install a brace as well.
1992forever
Feb 19, 2015 05:09 PM
badtomatoes
Feb 22, 2007 10:37 PM
do49
Dec 30, 2006 12:16 PM
f150lariat
Apr 7, 2005 08:26 PM
don_79f250
Apr 15, 2004 06:29 AM
