Where to look next?
Old Apr 11, 2012 | 07:55 AM
gurueuey's Avatar
gurueuey
Where to look next?
I have an 89 F-250, 351W, 5 speed. The problem I'm having is sluggishness and "missing" (truck shudders and loses power and speed) when trying to accelerate at lower rpms (under 2.5k) while at highway speeds. If I'm at higher rpms, or at lower speeds (1st and 2nd gear) I don't have a problem. The truck is also idling rough when cold.
Here's what I've done so far:
New coil, plug wires, cap and rotor, ignition control module, and plugs (autolite copper)
Verified plug gap (all at spec.), and timing (stays steady at 10 degrees)
New fuel filter and fuel pressure regulator.
Checked all the hard vacuum lines for leaks, replaced the ones that were bad.
Checked for intake leaks, none detected.
Removed the idle air control valve and cleaned it using Sea Foam
Sea Foam'ed the snot out of the intake, running a pour-in bottle through the tank, then ran her out on the highway for a while to help blow out any carbon.
Verified fuel pressure, steady 42lb. at the test port.
Not getting any codes.
Okay, not sure where to go from here, I don't hear anything like a sticking valve, but I suppose that I could have a lifter going bad. I've considered replacing the idle air control valve, would that have anything to do with it? Getting a little tired of just throwing parts at it, any suggestions would be appreciated.
Old Apr 11, 2012 | 09:07 AM
subford's Avatar
subford
You could try changing the spark plugs to Motorcraft ASF-32C plugs.
Gap them to .042-.046".
I have heard of not standard plugs doing that.
Old Apr 11, 2012 | 03:22 PM
gurueuey's Avatar
gurueuey
I was mistaken, they are the Motorcraft plugs. That's what I get from going from memory.
christiansranger92
1983 - 2012 Ranger & B-Series
Apr 19, 2010 02:12 PM
mcn420
3.8 & 4.2L V6
Jun 12, 2009 08:24 AM
Fatstrat
43
Dec 23, 2005 07:45 PM
Machman
Aerostar
Nov 6, 2004 03:44 PM
areyou4real
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 29, 2004 06:49 AM
