First of all, I want to appreciate men who replyed me. Thanks for supporting me in my trouble.
I had checked FICM block, it is in working condition, I had find F-250 in Riga, and even changed blocks and relays between mine Exc and F-250, F-250 was easily started with my FICM block and relays. I had pointed one thing !
When I have key in On-buzzle mode, I'am not hearing injectors sound.
May someone comment this?
Finally we had replaced in F-250, fuel injectors from my Exc, they not working. FICM test have above 45 V in all meassures. So conclusion at a moment is - injectors are dead.
May be it is different soft on the FICM blocks, but both working at F-250, and no one at mine dead Excursion (((. Tommorow we'll replace injectors from F-250 to my Exc and will check again. Quet interesant to know, what reason for, this trouble occured.
