Code 27 airbag,,, Not the usual
Old Apr 9, 2012 | 07:55 PM
newstang's Avatar
newstang
Ok, Did the bulb, thing, code 27.
My light works, even tested the reed switch, everything works.
I still get a code 27. Looked under seat( pass side ) no connector to be seen.
I am looking for the airbag module, but cant find the location anywhere, I will take a sledge hammer, plasma cutter, Torch and .357 Magnum Hydra-shock to it when I find it :-)
Whats the scoop? Anyone :-)
Old Apr 9, 2012 | 08:04 PM
F350-6's Avatar
F350-6
Try this attachment
File Type: pdf
Old Apr 9, 2012 | 08:07 PM
F350-6's Avatar
F350-6
You tried all that? Don't think there's a connection under the seat for the airbag. The passenger plug should be behind the glove box
I'll have to look to see where the module itself is (think it's under the tranny hump). Once we find it, we can decide on which weapon would be most appropriate to dispose of it.
Edit: nevermind. It's not under the tranny hump.
File Type: pdf
Old Apr 9, 2012 | 08:22 PM
newstang's Avatar
newstang
Hi Chris, most of the post was all dead pics,
Thanks for the help anyway.
So the PAD is behind the Glovebox?
If so do I need to remove the neg on the batteries before doing this?
So I assume a sledge hammer on the module wont work :-)
Old Apr 9, 2012 | 08:39 PM
F350-6's Avatar
F350-6
Hmm. I don't see the dead pics. I'll have to try and look at it not logged in to see what you're seeing. What about the pdf attachment in my last post? Can you see that? Yes the PAD is behind the glovebox.
Edit: I see what you mean. I went back and edited the first post and changed it to an attachment. See if that works better.
Old Apr 9, 2012 | 08:45 PM
newstang's Avatar
newstang
sledgehammer no good?
Old Apr 9, 2012 | 08:48 PM
F350-6's Avatar
F350-6
Sure, you just have to remove it first. Be sure to disconnect the batteries before you play with it so it doesn't get the first shot.
Flatbed79F250
2004 - 2008 F150
Jun 23, 2015 09:34 AM
pmbard
1997 - 2003 F150
Mar 17, 2014 09:26 AM
Turbo_Bimmer
Oct 5, 2011 06:42 AM
KEVINS800
1983 - 2012 Ranger & B-Series
20
Jan 17, 2005 12:02 PM
B D
Electrical Systems/Wiring
Oct 22, 2004 03:06 PM
