i need help with engine sounds.
Old Apr 7, 2012 | 10:00 PM
codafisler's Avatar
codafisler
i have a 390 with a steel crank in my 68. it has straight pipes right now on the original exhaust manifolds. when im driving down the highway and doing about 40+, if i let off the throttle all the way or even about halfway. i hear loudish popping sounds. only wen i let off the throttle tho. can anyone tell me what might this be and if it is bad? i can record it and upload it for you guys if you need it.
thank you for your time.
Old Apr 7, 2012 | 10:36 PM
70-360fe's Avatar
70-360fe
Sounds like an exhaust leak some where. Could be exhaust donuts/gaskets are worn.
Old Apr 8, 2012 | 09:21 AM
MIKES 68 F100's Avatar
MIKES 68 F100
straight pipes will do this , something about the back pressure when you let off .
please post a video/sound i'd love to hear an fe straight piped .
Old Apr 8, 2012 | 10:22 AM
70-360fe's Avatar
70-360fe
Might help if you put an H pipe in there to help egual out the pressure. Hopefully some one that knows more than me about H pipes will post.
Old Apr 8, 2012 | 04:04 PM
jowilker's Avatar
jowilker
I'd suggest getting a muffler under your feet, that in itself should help a lot.
John
mattyg50
Dec 4, 2007 02:53 PM
5.0Torx
15
May 9, 2007 01:28 PM
modelnerd
May 17, 2005 02:09 AM
loudwayne
Jan 10, 2004 07:32 PM
Jimbo101
Exhaust Systems
Apr 10, 2002 04:18 PM
