Fuel Return ?
Old Apr 5, 2012 | 09:15 PM
kdagenais's Avatar
kdagenais
Fuel Return ?
I have a 95 F150 with 4.9 engine and when I run the rear tank it fills the front tank. Also have a fuel bleeding issue mainly during day time when hot have to cycle key 3 to 4 times to start normal. Would these problems possibly be tied together or is the selector valve issue for filling the front tank. Be nice if they where tied together but sure I am not that lucky.
Old Apr 5, 2012 | 10:03 PM
bigpapa1987's Avatar
bigpapa1987
that switch valve is a curse to all these trucks and who ever invented it needs a kick in the ba**s . that is your problem and bother are tied together . be prepared to spend about 230.00 for a new one
Old Apr 6, 2012 | 06:17 AM
ncranchero's Avatar
ncranchero
The 95 doesn't have a switch valve. The check valve in the front fuel tank "module" is bad. Yes, it's also bleeding pressure off for the same reason.
Old Apr 8, 2012 | 11:53 AM
kdagenais's Avatar
kdagenais
Thats what i wanted to hear so change the fuel pump in front tank and will fix two problems at the same time. just put a entire can of sea foam in it and seems to be starting fine for right now.
Old Apr 8, 2012 | 12:25 PM
ncranchero's Avatar
ncranchero
It's possible that the check valve gummed up or caught a bit of trash and hung open. That's not the way my luck runs though.
Old Apr 8, 2012 | 04:30 PM
kdagenais's Avatar
kdagenais
i am sure its temporary and will have to change it shortly but just buying time is all.
Jonnys.1991
Apr 11, 2016 08:18 PM
spaytons
Mar 14, 2014 08:24 AM
F150Guy87
Oct 1, 2004 08:35 PM
dan_da_mick
Jun 15, 2003 12:38 AM
Fordman
Oct 28, 1999 08:14 PM
