Tuner and Traction Bars
First off let me say, I am new to Diesels and not really mechanically inclined .
I purchased this truck to haul our horses and alpacas. I am looking to do a DFP/CAT delete which comes with a tuner, to make the truck last as long as it can. Will I need to put on traction bars with this setup?
Oh yea... 09 F250 126K miles...
Thanks in advance
Thanks in advance
You only need traction bars if you are lifted or plan on going way over 600 hp. Since you are going to tow you are probably only going to be at 450 HP or less on a tuner so you would be fine.
Which tuner comes with the delete kit? the only two that are widely used and praised are the H&S Mini Max or Black Max tuners and the Spartan tuners. The rest of them either do not have tranny tuning along with them or they are not mirrored to the power increase very well.
I don't think that this is a lift kit. I have an F350 with the bottom block only which is the about six inches on mine but it is a stock part. The top block you have I believe is the spacer to make it look like an F350. If anything you have a very small lift. Anyone with an F250 want to comment?
ok i just crawled by big butt under there and measured that middle block it is 3" the picture makes it look taller than it is. The top block is 1 3/4"... Do you think I will need traction bars? I am just trying to figure out how I'm going to tell the "boss" with the purse that I am going to need to spend another chunk of change on more parts for this truck we have had less then a week
She was OK with the delete kits because they will help with the life of the engine.
