'49 Radiator info
Old Apr 4, 2012 | 08:09 AM
john fin's Avatar
john fin
'49 Radiator info
Does someone have a loose brass radiator laying around they can drop on a scale for me. I think mine is fill of gunk and weighs in at 38lbs. Radiator shops in my area are a thing of the past so I cant have it cleaned the way it needs to be.
Old Apr 5, 2012 | 06:47 PM
age62newbie's Avatar
age62newbie
John:
I weighed two (Cody, you need to come get yours!) brass I6 radiators, each one scaled at 32 pounds.
Take this with a grain of salt, because:
  • you didn't specify I6 or V8, I can't believe it would make much difference
  • neither one of these has been boiled out
  • my electronic bath scale seems to be pretty accurate at 180 (okay, 205) pounds, don't know how close it is at 32.
Old Apr 6, 2012 | 01:51 AM
51PanelMan's Avatar
51PanelMan
I once had about four spare radiators. All were cleaned out and boiled. One of them was heavier than the other three. Likely because of a different core(??).
Old Apr 6, 2012 | 07:19 AM
john fin's Avatar
john fin
radiator
Thanks for the info. I am going to use Marine clean por-15 on in and see what happens. Stuff work great on fuel tanks.
Old Apr 6, 2012 | 04:11 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Oh come on now, just give it the old farm boy special and be done with it.
Drag it out into the dirt next to the drive way, crank the ol garden hose up on high and stuff it into the lower hose outlet. Grab a red rag and smush it in around the garden hose to make a bit of a seal and let it rip. Every once in awhile reverse the flow of water until you get good clean stuff coming out and your're standing in a huge puddle of muddy water.
Now, dry off, got get a frosty beverage and pat yourself on the back for a job well done
its not healthy to overthink a dirty radiator
Bobby
Old Apr 6, 2012 | 04:27 PM
4tl8ford's Avatar
4tl8ford
What size garden hose should I use 5/8 or 3/4 inch - Oh and should it be rubber or plastic?
Old Apr 6, 2012 | 08:50 PM
51PanelMan's Avatar
51PanelMan
I once cleaned the inside of a radiator with a pressure washer.
Old Apr 6, 2012 | 09:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Average cost to restore a Bonus Built = $15,000
Average price of a flathead rebuild = $2,500+
Average price of professional radiator rodding/cleaning = < $100
This seems like a no-brainer
Old Apr 6, 2012 | 10:51 PM
bobbytnm's Avatar
bobbytnm
LOL....
Dick...this is a Bonus Built, The only hose size specifically required is a 13/16th
.....don't worry though. I'm sure NumberDummy can give us some part numbers for the factory hose
Old Apr 6, 2012 | 10:58 PM
havi's Avatar
havi
I'll have the Roast Duck
grocery store variety vinegar w/5% acidity mixed with 5 parts water will give ya a diluted solution of acetic acid to clean out your radiator. Pour that mix into your rad. while laying it down, so none of it escapes, let it slosh around a bit, and then pour it out after 48 hours. That's a cheap version of what a rad. shop would do and charge ya $45.75 in the process. Should clean out all the crud and make the rad. weigh the stock ballpark of 32 lbs.
Old Apr 6, 2012 | 11:11 PM
bobbytnm's Avatar
bobbytnm
What!?!?!?!?!
Its supposed to weigh 32lbs???? Crap! I am so screwed....I think mine weighs 33lbs. I'll never be able to drive this on the street..........
Old Apr 7, 2012 | 02:41 AM
FortyNiner's Avatar
FortyNiner
Great suggestion Havi - I had forgotten about Hints from Heloise's favorite problem solver. I'll put it to use on a heater valve!
DW
benwantland
Jan 29, 2023 06:35 PM
John & Old Ford
13
Jul 28, 2012 11:04 AM
Farm Use Only
16
Jun 12, 2007 10:08 PM
deisele75
Jul 16, 2005 01:14 AM
GeneStoner
Jan 15, 2003 05:08 PM
