f1-yblock
Old Apr 3, 2012 | 10:46 PM
RiKi5156's Avatar
RiKi5156
f1-yblock
Does anyone have any experience at putting a yblock into a 52 F1? Doesnt seem to be room for the generator down low on passenger side. Any ideas? I'd like to keep the generator. Rich
Old Apr 4, 2012 | 12:07 AM
ALBUQ F-1's Avatar
ALBUQ F-1
'52 BIG trucks were available with the 279 and 317 c.i. OHV engines that were a lot like a Y-block. They used a single center front mount like the '53-on trucks. The angled braces a flat V8 uses for mounts were omitted and side brackets (see below) were added to the side frame rails. A crossbeam went between the brackets and caught the center mount. I imagine a similar setup would give you all the room you need.
Old Apr 4, 2012 | 04:59 AM
55 f350's Avatar
55 f350
stu had a yblock in one of the mh 4x4 bonus builts he has . it came with it installed and it used the same stuff to mount it ross is showing i believe . i got the y and stu has all the brackets etc. don't know if there are any differences from the flatty stuff and it maybe he can enlighten you . put an alternator on it with a bought or fabbed up bracket mounting it like a flatty up high in the middle above the intake . you can get flatty brackets easily , the oe ones , and or a 40 alternator bracket for a flatty from speedway to alter as needed . actuallt after looking at ross's pictures again it used the horseshoe collar like the flatty in stu's truck . i took it and some other things off to give back to him . maybe the flatty engine mount works with the y block ?
Old Oct 14, 2012 | 06:09 PM
RiKi5156's Avatar
RiKi5156
yblock 52 F1
Well I got my Y block Merc mounted in my 52 F1 and now I need to put an alternator on it. I see some kits available from the Ford suppliers. Any recomendations ? Rich
pezsox
Jul 23, 2019 07:51 PM
daltonjamesadams
Nov 19, 2013 05:34 PM
Dave58
Feb 4, 2008 01:28 PM
JByrd1173
Jul 4, 2004 02:57 PM
