1978 - 1996 Big Bronco
rear blocks>>install help
Old Apr 4, 2012 | 11:11 PM
GruesomeJeans's Avatar
GruesomeJeans
Originally Posted by Raleigh1
Best way to go with a full 4" lift set up for the rear is the shackle flip.
It is the easiest and most reliable way to gain 4+" in the rear.
There are many to choose from in many price ranges.
I have these and have had NO issues at all, those and a 3" AAL and they flex like mad!!
Other options and considered higher quality:
Ford Rear Shackle Flip Kit - Sky's Off-road Design
Universal Shackle Flip Kit - RuffStuff Specialties
So you use these with stock leafs? How do they work?
Old Apr 5, 2012 | 08:33 AM
Raleigh1's Avatar
Raleigh1
They work great, they give you lift by turning the shackle from pointing up to pointing down.
Ride is much better and you remove ALL blocks including the stock shim (which have a tendency to crack).
It really is the only way to lift the rear of almost ANY Ford truck.
Old Apr 5, 2012 | 08:38 AM
Raleigh1's Avatar
Raleigh1
When you do this it will move you axle forward about 1.5"
There are 2 ways to remedy this, first is to move the front hangers back, this means cutting off the rivets, measuring and drilling new holes and bolting them back in.
The other way is Zero Rate add a leafs. Now I know they look like blocks, but that would be incorrect.
They bolt into the leaf pack so they are considered a leaf spring.
There is NO chance these will get spit out (if installed properly)!
This is the way I opted to go FYI.
Old Apr 5, 2012 | 08:59 PM
GruesomeJeans
Oh ok. I see now, that does look like the way to go. How hard is it to do this work? I don't have a frame jack but i will be getting a hitch installed saturday so i can use that. Problem is, i have never done anything like this, will i have to pull brake lines or anything like that? I will probably have to have my brother or neighbor help but for the time being i can only dream.
Old Apr 5, 2012 | 09:14 PM
Edgethis's Avatar
Edgethis
Shouldn't need to mess with brakes lines for 1.5" Moving the mount is easy, just a PITA. look at your front leaf spring mount. It should have 3-4 bolts IIRC, all you have to do is take that mount off as Raleigh said and slide it back 1.5" and drill new holes, then get some quality bolts and put it all back together.
Old Apr 5, 2012 | 09:27 PM
Raleigh1's Avatar
Raleigh1
On the front hanger there is 4 7/16" rivets on each, same with the rear.
Use an angle grinder to cut the heads off and a punch to knock the rest out.
This is also a good time to replace the bushings.
Old Apr 5, 2012 | 09:53 PM
GruesomeJeans
Uuuuuuuuummm ya, so i don't really have an angle grinder... I do have a dremel with a small cutting disk. It works for metal but it might take a while. Also i don't know if i have a drill bit to be able to get through the frame metal. This might be a bigger project than i intended. And as for the 1.5" is that how much lift i get or the movement of the bracket? My aim is for 4" and it doesn't seem this will get me that height that i am looking for.
Old Apr 5, 2012 | 10:06 PM
Raleigh1's Avatar
Raleigh1
This will get you 4" of lift but move the axle 1.5" forward when you do it.
Go to Harbor Freight and get a $25 angle grinder, some cut off wheels and grinding wheels.
Drill bits are cheap, go slow and use cutting oil to keep the bit cool.
Old Apr 5, 2012 | 10:36 PM
GruesomeJeans
Oh ok that makes sense now. I'll have to wok on that.
Old Apr 10, 2012 | 09:44 AM
79250ranger's Avatar
79250ranger
So is the stock axle shim the block with a piece sticking out that looks like a garden shovel?
Old Apr 10, 2012 | 09:51 AM
79250ranger
Few more questions.... Can i use my old leaf springs if i do a shackle flip? And my hangers are rotted real bad, do i need to get hangers for my exact year and model? Or can i use different ones?
Old Apr 10, 2012 | 10:20 AM
Raleigh1's Avatar
Raleigh1
Yes you can use your stock springs.
The shackle flip will replace the rear hangers, if your front hangers are rotted then replace those.
Any Ford 3" leaf front hanger will work, they are all the same.
Old Apr 10, 2012 | 10:50 AM
  #28
79250ranger
When you say front hangers, do you mean the ones on rear springs?
Old Apr 10, 2012 | 11:19 AM
  #29
Raleigh1's Avatar
Raleigh1
Yes, the front spring hangers for the rear springs.
You can find them new for ~$50 each.
1980-96 OEM Front Spring Hanger Bronco
Old Apr 10, 2012 | 11:55 AM
  #30
79250ranger
thanks....cuz i have a 79 f250, and built a wooden flat bed....built it up pretty high, but when i loaded the bed with stuff, hit a bump and tire rubbed underside of bed....like i said before, the hangers are rotted, but still attached....I need hangers anyway, so hopefully if i do this, no more rubbing.
TheSterling
Mar 14, 2016 02:49 PM
GMT
Jul 2, 2013 04:54 AM
crazer42
16
Dec 20, 2008 04:50 PM
stealth1
Jun 10, 2007 09:52 AM
kmans777
Apr 20, 2006 11:12 PM
