cruise control
Old Apr 2, 2012 | 09:53 AM
big ole ford's Avatar
big ole ford
cruise control
Anybody got any diagnostic flow charts wiring diagrams or theory & operation info on these early cruise control systems mine is not working and is the only thing on my truck(83 f350 diesel) that dont work so its really buggin me! I have checked all of the obvious things fuses vacuum lines and no wires or connectors are damaged so with no additional info im stuck. I know alot of you folks on here worked for ford when these trucks were new enough to take to a dealership so im hoping someone knows something about these things.AS usual i appreciate all your info,Thanks
Old Apr 2, 2012 | 07:27 PM
Franklin2's Avatar
Franklin2
Look down through this forum at all the posts that are around a week old. There was a pretty large thread on just this subject.
Old Apr 2, 2012 | 08:31 PM
klricks's Avatar
klricks
Does your horn work?
I have a diagram from an '86. Link in my signature.
Old Apr 2, 2012 | 08:37 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
If I knew where Douglasville was I might be able to help you. I have a Rotunda cruise control tester.
Old Apr 2, 2012 | 09:54 PM
bruno2's Avatar
bruno2
Cruise control is a GM term. Speed control is a Ford term. Use the Ford term in your search also. Could be the servo. Make sure you have a good vacuum source going to it. Also sometimes the gears get all cattywompus inside the servo. You may need to take it apart inspect it and clean/grease everything back up.
travis182008
Feb 28, 2011 06:25 PM
IMPRTKLLRZ28
Dec 7, 2010 10:55 PM
BKF250
Jan 25, 2010 11:27 PM
focusyn
Aerostar
Mar 12, 2006 07:55 PM
1993F150
Electrical Systems/Wiring
Feb 6, 2004 12:43 AM
