rear axle seals
Old Apr 2, 2012 | 09:52 AM
joonya's Avatar
joonya
rear axle seals
hey everybody, i need some help. has anyone had problems with rear axle seals failing alot? i have changed mine 3 times in 2 years. anybody got any answers? it's really pissn me off. thanx
Old Apr 2, 2012 | 10:10 AM
Coskid's Avatar
Coskid
Are you the one changing them or did you have a shop do the work for you?
I have not heard anything about them failing this much so I would look at a few things. One the piece you are getting may not be the right seal so its failing easier. Two it may be put in wrong, certainly hope its something else but would certainly be something I would look at. Three I would look at what else is around or close to the seal that might be assist it in its failure.
Old Apr 2, 2012 | 11:26 AM
krane operator's Avatar
krane operator
Check that the axle vent tube is not clogged.
Old Apr 2, 2012 | 10:06 PM
joonya's Avatar
joonya
Thanx for the info I appreciate it. I'm startn to think its the axle shafts.
Old Apr 2, 2012 | 10:15 PM
joonya's Avatar
joonya
I did most of the work with a certified mech. Inspecting. The axle shafts on the last replacement looked a little worn. And eventhough the bearings are new I'm hearing a little clunking when it's cold out. So looks like i might have to rebuild the entire thing.
hvacguy460
Utah Chapter
Jun 4, 2018 02:20 PM
pacrewchief
Jun 9, 2012 09:12 AM
gcfisher75
Nov 23, 2003 09:57 AM
Marv 02
Jun 25, 2003 10:26 AM
