Ever installed an Edelbrock...
Old Apr 2, 2012 | 09:05 PM
Anafiel's Avatar
Anafiel
Originally Posted by jeremywood30
Where do you purchase this plate? Your the second person to mention this!
Does this look like what you would need to block off the "hole"? This is the plate I used on mine.
Edelbrock 8981 - Edelbrock Choke Block-Off Plates - Overview - SummitRacing.com
Old Apr 2, 2012 | 09:11 PM
bruno2's Avatar
bruno2
Thats the one I used on mine. Seems like it is located on the passenger side of carb almost directly beside it. I cant remember if I got the Ededlbrock or a more generic one.
Old Apr 2, 2012 | 09:22 PM
jeremywood30's Avatar
jeremywood30
4wd Low
That plate came with the intake manifold I purchased. It's for the manual choke. You will block it off if you have an electric choke.
The vacuum tree's from the factory intake don't fit the two holes I have on the aftermarket intake. I will need to make some I guess. Any idea's on this.
Old Apr 2, 2012 | 09:26 PM
Anafiel's Avatar
Anafiel
Sounds like it's time for you to take pics and post them.
My factory vacuum tree fit just fine in the rear hole of the manifold. I'll take pics and post them tomorrow.
Old Apr 2, 2012 | 09:37 PM
bruno2's Avatar
bruno2
The heat riser is different than a choke . It does help warm the truck up. An electric choke works off of voltage where a manual choke works off of a cable and lever run inside the cab.
The factory manifold should have one true vacuum port on the back of the manifold at 12:00 directly behind the carb. Then there should be 2 water passage NPT ports in the front. One is for the temp sender and the other is for a water temp activated vacuum valve tree.The valve has a constant source of vacuum running to it , but , is closed while the engine is cold. Once the water temp heats up it opens the vacuum valve for the emissions and then that tree is charged with vacuum.
I will go look at my OEM Ford 351W 4 bbl manifold and see if it has more than 2 plces for the vacuum trees.
Old Apr 2, 2012 | 09:40 PM
ctubutis's Avatar
ctubutis
I have never heard of an EFE valve before, I have a hard time understanding how (at least some of) these trucks are supposed to have one....
Old Apr 2, 2012 | 10:22 PM
jeremywood30
4wd Low
Old Apr 2, 2012 | 10:39 PM
Anafiel's Avatar
Anafiel
Oh, foot in mouth moment....
I'm NOT using the manifold you have shown there. I use this one.
Edelbrock 2181 - Edelbrock Performer Intake Manifolds - Overview - SummitRacing.com
I don't have a clue what to advise you on yours.
Sorry...
Old Apr 2, 2012 | 10:56 PM
bruno2's Avatar
bruno2
Those three bungs across the back loo like vacuum ports. If they are then plug the one you trying to fit the trees into and use them. You may need a reducer bushing on the smaller 1/4" NPT tree, but manifold vacuum is manifold vacuum.
That horizontal vacuum port looks to be 1/8" NPT . Just get a pipe plug that size and plug it.
Old Apr 2, 2012 | 11:05 PM
ctubutis's Avatar
ctubutis
It's been forever since I've owned or worked on a 351W, but the attached pic is how my 400's factory manifold was originally configured (now running a Performer 400 and lots remained the same, I'm pretty sure even the sizes of the fittings (which should be standard pipe threads IIRC and such fittings can be gotten from the JY pretty easily in my experience)).
Thanks for posting pictures, they help.
Old Apr 3, 2012 | 12:22 AM
jeremywood30
4wd Low
Question
The vacuum area in green, isn't that a coolant hole?
Old Apr 3, 2012 | 08:37 AM
Anafiel's Avatar
Anafiel
That IS some kind of coolant crossover passage, isn't it guys?
Old Apr 3, 2012 | 08:39 AM
  #28
bruno2's Avatar
bruno2
Blow air into a port you know is vacuum for sure and see if the air comes out the port with green arrow or blow air into a known coolant port.
Old Apr 3, 2012 | 09:00 AM
  #29
ctubutis's Avatar
ctubutis
Very well could be, it looks like it's in the middle of a crossover passage that I guess could very well contain coolant but I have no idea what would connect to it if it is.
Old Apr 3, 2012 | 11:24 AM
  #30
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
On a 302 or 351W, the very front and very rear ports are coolant passages. On a 351M or 400 they are usually air passages for the Thermactor system.
