Vacuum leak?
Old Apr 1, 2012 | 09:34 PM
MGarner's Avatar
MGarner
Vacuum leak?
My wife's '59 F100 223, 3 on the tree loses power when under load. Starts good and idles ok. Has power in 1st and 2nd gear but when she shifts to 3rd it starts losing power. Especially climbing a small incline. We did a complete tune-up. We found what seemed to be a small vacuum leak and repaired it. and it did run somewhat better. We were wondering how to test for other vacuum leaks. Anybody else had this problem? New fuel filter? Carb. rebuild? New fuel pump?
Old Apr 1, 2012 | 10:34 PM
dmack91's Avatar
dmack91
You can try spraying WD40 around the carb base and intake to block junctions. If the engine speeds up upon application, that would indicate a vacuum leak. Be careful around any source of high heat or flame.
Old Apr 2, 2012 | 12:32 AM
52 Merc's Avatar
52 Merc
A more likely culprit is your distributor not advancing correctly. If the advance is not working up to spec, it can create all kinds of drivability issues. You might even have a ruptured vacuum advance diaphram, if equipped, which would cause both a vacuum leak and a non-op advance. A vacuum gauge would be a good investment for checking that.
Old Apr 2, 2012 | 08:57 PM
MGarner's Avatar
MGarner
Thanks guys for the info. I would be pulling my hair out if it wasn't for the advice on this forum and some super nice people willing to help a novice out. Thanks again!
Mickey
Old Apr 3, 2012 | 12:30 PM
petemcl's Avatar
petemcl
I agree with 52 Merc. That was one of the problems that I had.
Here is a handy chart to use with a vacuum gauge attached to the intake with the engine running. Kinda old school but very effective.
Old Apr 3, 2012 | 06:08 PM
old_dan's Avatar
old_dan
My son has a 66 Mustang with a 200 6cyl. The vacuum diaphram had become broken for the distributor advance. It ran OK, but I popped the hood to check it one night & we could see the exhaust manifold glowing red hot from the late ignition. The vacuum gauge will tell you about the condition of the engine, but you need to attach a piece of hose to the distributor vacuum diaphram and either put a vacuum pump on it and watch the plate inside the distributor (pop the cap), or suck on the hose and watch the plate....it should move. If you suck on it and air flows without any resistance, the diaphram has failed.
Also...check your fuel filter. Those symptoms could be a lot of things.
Dan
JRT812
Jul 25, 2017 10:59 AM
dharte
Nov 1, 2014 06:28 PM
